07-31-2018, 03:36 PM | #1 |
Non A/C Heater Core
Hey Gang. I recently inherited my Dads 1968 GMC 2500 Series truck and while going through it to make it road worthy I found the heater core was leaking. After some searching on the web, it shows that the inner fender is required to come out to remove the heater/blower box. My truck is a non A/C truck and after looking around a bit at the truck I have my doubts if that is true. Has anyone else changed a heater core in a non A/C truck without removing body panels, or even worse, cutting open the heater box to get to the heater core? Thank you in advance. Oh, Bytheway, I am a newbie here, and my name is Mark.
07-31-2018, 03:49 PM | #2 |
Re: Non A/C Heater Core
Welcome!
You can take out the inner fender or loosen the hood hinge and move it forward a bit. Maybe you can sneak the case out by pulling the blower motor first, but I've never done it that way. It's really pretty easy to take these trucks apart.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
07-31-2018, 03:56 PM | #3 |
Old member
07-31-2018, 03:56 PM | #4 |
Hi Mark, My truck is a 1967 non a/c truck. When I changed my heater core, I did have to remove the inner fender, but it was worse thinking about it than actually doing it.
It was several years back but as I recall, I loosened the passenger hood hinge where it fastened to the inner fender and slid a 2x4 on top of the fender from the driver side fender to the top of the passenger side fender & supported the hood hinge. The inner fender bolts ran mainly just inside the wheel well and the other attachment points were pretty visible as I recall. Some of the inner fender bolts were a different length, so pay attention to that. It will save you a couple of minutes when you re-assemble it. Once the inner fender is loose, you can slide it down a couple of inches which gives you access to the heater core cover bolts. It’s pretty simple after that. Hope this helps. Last edited by Freddo; 07-31-2018 at 03:58 PM. Reason: Spelling |
07-31-2018, 04:00 PM | #5 |
Hello Clay, thank you for your reply. The hood is already off of the truck as I am putting the final touches on installing a fresh motor in the truck, so removing the hood hinge is not a problem. I just don't want to get into something to further along the project than necessary at this point. I am waiting on a bit of exhaust hardware so after that I can drive this thing.
07-31-2018, 04:09 PM | #6 | |
07-31-2018, 04:25 PM | #7 | |
07-31-2018, 04:26 PM | #8 |
07-31-2018, 04:46 PM | #9 | |
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
07-31-2018, 06:12 PM | #10 |
Dropping the fender and moving the hood hinge definitely helps - and makes getting everything reassembled (in my case) easier when dealing with the gasket/seal..
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
08-01-2018, 01:11 PM | #11 |
That huge dent is probably there from the last time when you were a kid. That probably helped with removal.
08-01-2018, 06:48 PM | #12 |
08-02-2018, 02:03 PM | #13 |
Somebody pounded that fender down to remove the heater core once before.
If you reinstall with a new heater core, you can leave out that one bolt that is hard to get to for easier removal for the next owner.
1970 C10 8' Fleetside, L6 250, 3 on the Tree. The most basic of pickup trucks! |
08-02-2018, 03:00 PM | #14 | |
Posted via Mobile Device |
