Old 07-31-2018, 05:00 PM   #1
Slowy-gonzalez
1957 big rear window replacement
I ordered a new rear window for my 57,when I went to install it, its a little to small, I would say a 1/8 or 1/4 of and inch too short, I remember reading somewhere that sometimes the new replacement glass is a little too short,
you can see the edge of the glass on both sides, I also replaced the gasket around it with a new one, what gives, anyone remember having this issue?
2017 king ranch power stroke
57 chevy big rear window, camaro front clip, rear is notched
57 chevy truck, air ride, ls swapped.
52 chevy truck waiting its turn.
Slowy-gonzalez is offline   Reply With Quote
Old 07-31-2018, 06:18 PM   #2
Sammy4358
Re: 1957 big rear window replacement
I replaced the rubber on my 59 big window and had to buy three different window gaskets because the rubber was to thick by 1/8' to 1/4". I found the correct rubber for the stock window at Steel rubber products. I guess the first rubber seals I purchased were for the new glass that is smaller than the stock glass, I have an extra seal that is to small for my stock glass if you want to try it
Sammy4358 is offline   Reply With Quote
Old 08-01-2018, 01:32 AM   #3
Dan in Pasadena
Dan in Pasadena's Avatar
Steele Rubber is reliably the best.
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Dan in Pasadena is offline   Reply With Quote
Old 08-01-2018, 05:31 PM   #4
Russell Ashley
Russell Ashley's Avatar
I wanted to buy the gasket for my BBW from Steele but they told me that they didn't have the chrome lock strip. I ordered one from Bowtie Bits as they sold it with either black or chrome lock strips.
Russell Ashley is offline   Reply With Quote
Old 08-04-2018, 04:43 PM   #5
Slowy-gonzalez
I also remember reading that depending on where you get the actual rear glass , there is a chance it might be a little too "small" , anyone had this happened? Where did you get your glass from?
