08-05-2018, 01:24 PM | #1 |
rear brake hose union location
I am redoing my whole brake system, and ran into a problem with the rear brake lines. I bought a new stainless line kit from Right Stuff several years ago. I went to install them yesterday and the lines are not the right length. The driver side is too short and the passenger side is too long.
My truck is 1 71 1/2 ton, coil springs. Here are a couple of pictures. Does anyone have a picture of how theirs are? My tab is broken off the rear end housing so I could some help figuring out where that attaches as well. Thanks!
71 Chevy C10 Shortbed Stepside. LT1 with 4l60E. Just got back from painter, in assembly now. |
08-05-2018, 04:30 PM | #2 |
Re: rear brake hose union location
You need the brass union that connects those brake lines together. You will also need to install the missing tab on the axle housing because a spring clip attaches at that connection.
Here is a photo that might help. POP
2016 RAM Laramie HEMI 1966 Fairlane GT/A, 390/335 HP If it costs you a dollar to make a friend, KEEP THE DOLLAR. If it costs you a friend to make a dollar, KEEP THE FRIEND. |
08-05-2018, 04:38 PM | #3 |
Thanks, Pop. The picture definitely helps. I do have the Union as it is part of the brake hose but the tab broke off of the rear end housing. I still have it so I'll just tack it back on. I have ordered some new lines, hopefully they will solve that problem
08-05-2018, 04:51 PM | #4 |
No need to order more lines.. Simply straighten each bend a very slight amount.. You'll gain the "missing length" easily enough..
08-06-2018, 07:22 AM | #5 |
A little mini hijack, since these pictures are so good. I think I may have this or similar rear end. Been chiseling 45 years of crud off of it to get a better look, but I could not locate a fill hole for it. How do you check level or fill this thing, do you use the vent tube orifice?
08-06-2018, 05:58 PM | #6 | |
Who Changed This?
Keep scrapin'!
08-07-2018, 07:22 AM | #7 |
I read passenger side somewhere yesterday, but didn't get a chance to crawl under and hunt for it yet. But, yeah, you might be right about someone not caring to check it in a LOOONG while. Going to update my thread with questions so as not to hijack this one to badly.
