Old 08-06-2018, 02:33 PM   #1
Curt - TN
Older Dolphin Speedometer Setup (8 Dip Switch)
I was so excited that my project truck came with a brand new set of Dolphin gauges until I found out the were 10 or 12 year old new
The speedometer I have has 8 dip switches on the back for calibration and all the instructions I can find have 9 dip switches. I am tied into the VSS wire on the 4L60E trans and as soon as I got 5 MPH the speedo pegs.
Do any of you have set up instructions for the Dolphin speedometer with 8 dip switches?
I called Dolphin and they said they are having a hard time finding documentation on an old one like this. I would replace the speedo but they changed from black needles to red which means I have to swap both gauges and maybe all the sending units.
Thanks,
Curt
Brentwood TN
1950 Chevy 5 Window 3100 - Check out my Build Thread: http://67-72chevytrucks.com/vboard/showthread.php?t=724260
1957 GMC 100
Curt - TN is offline   Reply With Quote
Old 08-06-2018, 03:46 PM   #2
mikebte
Re: Older Dolphin Speedometer Setup (8 Dip Switch)
Thanks,
Do you have a picture of the back? I am running the 4L60E but I have the Dip switch set up on the VSSB for calibration. Check out this page and see if it helps any.
http://www.alanhorvath.com/54chevy/dolphingauges.php
If you have a set of Dolphin Gauges and you have the electronic speedo, here's how:
Quote: You are going to pace or follow another car with an accurate speedometer. First, go to the backside of your speedometer and remove the rectangular rubber cap. Put switches 3, 5 and 6 in the up position ... all other switches go in the down position for your road/pace test. You and the pace car will drive at 55 mph ... note what speed your gauge is reading.
1 - 34 mph: http://www.alanhorvath.com/54chevy/c...o_adjust_1.jpg
35 - 68 mph: http://www.alanhorvath.com/54chevy/c...o_adjust_2.jpg
69 - 102 mph: http://www.alanhorvath.com/54chevy/c...o_adjust_3.jpg
103 - 136 mph: http://www.alanhorvath.com/54chevy/c...o_adjust_4.jpg
1959 Chevy Apache 3100/ 283 TBI / 4L60E
My YouTube:
https://www.youtube.com/mikebtte
mikebte is offline   Reply With Quote
Old 08-06-2018, 03:56 PM   #3
Curt - TN
This is the back of mine. I tapped into one of the two wires at the transmission, I am wondering if it is sending out different pluse than the speedo is expecting.
Curt
Brentwood TN
1957 GMC 100
Old 08-06-2018, 04:07 PM   #4
Curt - TN
I found this page in the past and it looked hopeful until I click into the speed links to adjust and the chart shows 9 dip switch options. I believe my speedometer is older that that with 8 dip switches.
Curt
Brentwood TN
1957 GMC 100
