08-06-2018, 07:00 PM | #1 |
WTB seat bottom springs
Having my seat recovered & found out several bottom springs were broken & rewelded. Would like to find some replacements. Any one with a seat or willing to remove the springs please let me know.
Thanks Scott
1963 C10 swb fleetside 1966 GMC G1000 Handi-bus (future project) 1955 Chevy 2 dr. wagon |
08-06-2018, 08:21 PM | #2 |
Re: WTB seat bottom springs
Are you talking about the long repeating "s" that runs front to back? Or the actual spring that holds you up? Sorry I don't know a better way to describe.
08-07-2018, 12:06 AM | #3 |
Attached is a pic of the springs, looks like they run front to back. Looks like the welding took the temper out of them, so best to replace them now.
From the looks of it I need around 7. Any help is appreciated. Thanks Scott
08-08-2018, 11:57 PM | #4 |
still looking
08-09-2018, 06:08 AM | #5 |
have one in ct if you want to come up and get it.
08-09-2018, 09:48 AM | #6 |
Thanks 4 the offer. Might be interested in picking it up, what year did it come from?
08-09-2018, 08:03 PM | #7 |
66 k20
08-09-2018, 11:37 PM | #8 |
PM sent
08-19-2018, 07:56 AM | #9 |
Hey Scott, I just got to the seat this mourning and it does not look like yours, this was out of an original 66 k20. Let me know what you want to do, if you don't want it I am going to scrap it.
08-19-2018, 09:11 AM | #10 |
I have springs and new spring clips for installing also you can add these reinforcement panels to add support , the side springs can be replicated using regular z springs when bent correctly
https://www.albrightssupply.com/Zig-...4-p/sp2024.htm https://www.albrightssupply.com/Flex...8-p/flex18.htm the flexolator panel you would need 60" to go across the seat bottom ,You attach them on top of the seat springs use burlap between the stock springs and flexolator then seat padding
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
08-19-2018, 10:03 AM | #11 |
thanks guys, the upholstery guy was able to come up with a fix.
08-24-2018, 03:24 PM | #12 |
Grumpy old man, do you have a set of the straight seat bottom springs that you're offering up?
If ScottH is passing on them I would be interested in talking with you about what you have. Thanks.
Curt 1970 C/10, 250 L6 with Rochester BV carb, SM465 4 speed, 3.73 open rear |
10-02-2018, 09:37 PM | #13 |
I'm also looking for a couple of those springs for my 65. I have 3 that are broken off where the coil connects to the frame. Any tips would be awesome.
