08-07-2018, 11:08 AM | #1 |
Junior Member
What would cause a float to split open and deteriorate so soon?
Two years ago I replaced the sending unit in the 1970 C10.
Recently, the gauge stopped working and after troubleshooting figured out the float had literally split open and peeled like a banana. See the pic of the old and new sending units side by side for a comparison. I had ordered a new sending unit just in case... So, install the new stuff and test it, works fine. Go about working on a few other things with the truck for a couple of days and start the truck and fuel gauge has stopped working again. I pull the sending unit and the shiny brand new float is now completely stripped and you can just see where it has split along the seam after just a couple of days. What the heck would cause that? I use Marathon, 90 octane, ethanol free gas with K100 additive fuel treatment.
08-07-2018, 11:50 AM | #2 |
Re: What would cause a float to split open and deteriorate so soon?
Happened to my new one also. Buy a Jeep plastic float for under $10 and replace the brass one per this thread.
http://67-72chevytrucks.com/vboard/s...d.php?t=666161 |
08-07-2018, 12:30 PM | #3 | |
Junior Member
08-07-2018, 03:41 PM | #4 |
Solution applied to China, attempting to give a dam, Dam not giving.
Thanks for posting! My original is still in, 49 years and counting, using ethanol 87! |
