![]() Join Date: Nov 2006
My bed has started rattling like its loose
What could cause this guys. Its driving me nuts........
I BELIEVE IN JOHN 3:16 |
![]() Join Date: Feb 2010
Location: Falls City, Nebraska "100 Miles From Nowhere"
Re: My bed has started rattling like its loose
Retightening the bed to frame bolts is almost routine maintenance...I think over time with periodic loading, and bumps collapse the bed metal and cross members just enough to cause the bolts to loose their initial torque. Once loose, the hammering effect will cause a nut to loosen even when lock washers are used. A flat washer under a lock washer can loosen as well because the flat washer can slide instead of biting like the lock washer alone would. I have to retighten my bed to frame bolts (wood bed) once a year. No biggie because I'm usually underneath for other maintenance anyway. Might try 2" X 2" X 1/4" thick neoprene rubber spacers with nylon aircraft style lock nuts to see if that would hold?
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" ![]() "Be American, Buy American" ![]() |
![]() Join Date: Feb 2002
Rotten rubber body mounts -- decomposing and falling away, maybe?
Hard to say from here without pix.
Scrapper 1
On the 1960's 1960--66 had wood beds.I know they used rubber square bushings to put between the bed and the frame.It makes it so much nicer.it takes 2 people to put the bed o.You can use glue to make sure they stay in place but its helps me so much having cushion.Look in www.truckandcarshop.com web side look for Rubber cushions for under bed.It will really help your problem
There call bed wood mounting pads page 91 10.00 kit Me i buy a few kits cus it nice having them around |
![]() Join Date: Dec 2013
Check this thread it's probably just the tailgate hinges rattling .
![]() http://67-72chevytrucks.com/vboard/s...d.php?t=164555 |
no its definatly the bed, mostly in front. thanks fellas
#7 | |
Who Changed This?
![]() Join Date: Jan 2013
I'll have to check the bolts on my bed. I've never done it in the 10 years that I've had the truck.
When it rains it pours........... Lol. My muffler blew out last night.. Local shops want 250.00 plus tax for duals 2 1/4 galvanize and me furnish mufflers.............
Who Changed This?
That's a good price!
Yea i guess its good for here in e. Tn.
Who Changed This?
I had the pipe and one muffler added to my son's Dart to make it dual exhaust and got skinned $345 here in California, ten years ago. Labor prices are quite different between the two places.
#13 |
Moderator
![]() Join Date: Jun 2017
$250 is a good price...
LMC lists dual systems between $260 and $300...with stainless running $680... Dont scrimp on the exhaust... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
#14 |
I figure galvanize is next best to stainless. I remember the old days, 1970,s how the world has changed
#15 |
![]() Join Date: Dec 2009
I know of a good muffler shop in Murfreesboro Tn
But with the gas prices it would probably not be an option for you.
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
#16 |
On my 68 it was the upper rear shock mounts. Factory rivets were loose and made a terrible rattle over even the smallest bumps. I cut them off and used short shoulder bolts to replace the rivets. Big difference.
#17 |
So was the ''Bed Noise'' really the muffler fixin' to blow? Or do you still have the bed noise?
#18 |
no still got bed noise
#19 |
Who Changed This?
I'm sure you meant aluminized. Any welder who knows anything doesn't weld galvanized anything without stripping the zinc. I know guys who didn't and died from inhaling the zinc oxide fumes.
#20 |
yep, that's what I ment................
#21 |
Who Changed This?
Not trying to bust your chops...just so other people know.
#22 |
no problems here pal, in fact thanks
#23 |
I put rubber pads made from inner tubes between the bed and the frame where the fasteners hold the bed to the frame. glued in place by a calking gun full of black window sealer I bought from Ace for about 4 bucks. other sourced of noise could be a loose tail gate, loose shocks or a spare tire hanging loose under the bed.
#24 |
I think the rubber pads between bed n frame are bad.
