Old 08-11-2018, 03:04 PM   #1
CG
BlahBlahBlah
GMC to Chevy headlight question
So when going from GMC to Chevy I know the headlight connections are going to be different. Will I need to change the entire underhood harness, or is there a headlight section only section that I can just swap out?
Old 08-11-2018, 03:26 PM   #2
stsalvage
Scrapper 1
stsalvage's Avatar
Re: GMC to Chevy headlight question
You will need to change the Core support.The GMC is made for 2 head lights not one
stsalvage is offline   Reply With Quote
Old 08-11-2018, 04:14 PM   #3
Stocker
20' Daredevil (Ret)
Stocker's Avatar
As far as the wiring, just use the GMC's outer hi/lo connector for the Chevy's 7" hi/lo headlamps. The inner high-beam-only connector will not be used. If there's not a good way to remove those unused wires completely, I'd at least cap them off to prevent accidental grounding.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 08-11-2018, 04:20 PM   #4
CG
BlahBlahBlah
I already have all I need sheet metal wise. Was just curious about the harness. Ok looks easy peasy as far as the harness goes.
I haven't totally decided on the core support yet. I have the correct one, but I also know the GMC support is easily modified for Chevrolet. Ill have to look and see what all I have bolted to the core support. Its an air truck and it has auxiliary battery.
Old 08-11-2018, 04:28 PM   #5
4oldcars
4oldcars's Avatar
Bare in mind that if you do as Stocker says, when you hit the dimmer switch you'll be in the dark.
4oldcars
Driving:
1971 Jimmy w/68 Chev front clip, 1953 Bel Air 2 dr hdtp, 1996 Roadmaster wagon, 2000 Eldorado
The ones I let go:
1931 2 dr sedan, 1935 pick up, 1938 2 dr sedan, 1962 SS 454, 1963 409 wagon, 1970 short bed, 1972 short bed, 1972 sub, 1976 short bed, 1986 long bed, 03 short bed
4oldcars is offline   Reply With Quote
Old 08-11-2018, 04:28 PM   #6
CG
BlahBlahBlah
lol, oops
Old 08-11-2018, 06:28 PM   #7
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Explain please? Maybe I'm missing something, but the GMC's outer lamps operate as both high beam and low beam, selectable by the dimmer switch. Chevy's lamps are the same, having both high beam and low beam. They each use the same 3-prong connector (one common wire, one high beam wire, and one low beam wire). So why would you be in the dark?
- Mike -
RIP El Jay
Old 08-11-2018, 06:38 PM   #8
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
X2, you will still have high and low beams. There will be no darkness
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
Old 08-11-2018, 07:01 PM   #9
CG
BlahBlahBlah
Ok so basically I should never ever question advice again that I get from Mike?
LOL!!!
Old 08-11-2018, 08:00 PM   #10
Ol Blue K20
LOL!!!
EXACTLY! !!!!!!!!!!!!
Dale
Old 08-11-2018, 09:40 PM   #11
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Now if you guys could convince my wife about that.....
- Mike -
RIP El Jay
Old 08-11-2018, 10:23 PM   #12
Ol Blue K20
I could try but she probably knows you a lot better than I do
Dale
Old 08-11-2018, 11:37 PM   #13
Stocker
20' Daredevil (Ret)
Stocker's Avatar
After 47 years, I bet she does at that!
- Mike -
RIP El Jay
