08-17-2018, 02:48 PM | #1 |
Steering coupler question
Has anyone replaced this steering coupler? The one I have was damaged. I talked to a few online suppliers and they suggested a universal joint since they don't carry a replacement. Sounds like it would work. Any draw backs to that?
08-17-2018, 07:26 PM | #2 |
Re: Steering coupler question
Yep, just did that. I called up Borgeson and got a u-joint on the column which I connected to their "cut to fit" telescopic double D shaft and went with a vibration reducing u-joint on the steering box.
08-17-2018, 10:58 PM | #3 |
Thanks for the info. I will look into that.
08-17-2018, 11:42 PM | #4 |
Yeah, just give the tech support guy a call, he will help you with part numbers needed, and then you can simply shop for your best deal. I used Jegs myslef.
08-19-2018, 12:54 AM | #5 |
Cpp can make any combination rag joint you need
70 c10 long bed 57 chevy 2 door wagon 07 tahoe 96 civic commuter |
08-19-2018, 08:18 PM | #6 |
I'd guess a collapsible one from a later (67-~76) truck would bolt in. I think the input to the steering bo diameter changed in the late 70s.
08-20-2018, 10:30 AM | #7 |
Mine came from a junk yard but you won't find a new one there. I don't know if that part ever wears out though. The whole inner shaft assy that I took from a 67 was the same length as the 66.
