08-19-2018, 11:43 AM | #1 |
70 C20 750CFM Quadrajet Vacuum Hose Connections
Can you share some pictures that show the vacuum hose connections on your C20 quadrajet carburetor? Thanks in advance.
70 Chevy C20 3/4T 8-400 Longhorn |
08-19-2018, 04:05 PM | #2 |
Re: 70 C20 750CFM Quadrajet Vacuum Hose Connections
Search with ‘google images’.
https://www.google.com/search?tbm=is...24.mqR5qv2dJOQ |
08-19-2018, 06:12 PM | #3 |
Hmm, if only that easy.
08-19-2018, 07:27 PM | #4 |
How so?
You got a pic or a link to the carb you got? East to tell you what goes where that way. |
08-20-2018, 03:19 PM | #5 | |
Who Changed This?
My truck has the vacuum advance port on the front of the carburetor, opposite where the fuel supply line enters. PCV port is on the front. Choke pull-off (if you have an automatic choke) port is right next to the pull-off, with a hose about 1.5" long. The brake booster has a connection on the manifold, not on the back of the carb. There is another live vacuum line that attaches near the choke stove in the carburetor base plate; it goes inside the cab and is hooked to the (non-original) vacuum gauge. Transmission modulator vacuum also feeds from the manifold, like most vehicles. That's all I have on mine.
~Steven '70 Chevy 3/4T Longhorn CST 402/400/3.56 Custom Camper Simi Valley, CA Last edited by Steeveedee; 08-20-2018 at 03:25 PM. |
08-25-2018, 11:41 AM | #6 |
Helpful steeveedee, thanks.
