08-21-2018, 01:34 AM | #1 |
What is this for?
Does anyone know if this hole is used for something or can I block it off ?
08-21-2018, 02:02 AM | #2 |
Re: What is this for?
if I'm looking at your picture correctly, clutch linkage.. it gets a boot as it deflects slightly when it strokes..
ETA; relative to the floor mat button, looks more like speedo grommet.. can't remember exact size but it was big enough for the nut to slide all the way down to the trans, after I installed it the first time and assuming you're working on a 62, maybe clutch linkage routes differently? left to right in my '65 4spd picture, brake cable, speedo cable, clutch rod.. hope that helps, good luck!
I started out with nothing - and I still have most of it Last edited by Killer Bee; 08-21-2018 at 02:18 AM. Reason: think it's for speedo, not clutch |
08-21-2018, 02:52 AM | #3 |
Junior Member
in my 61 the speedo cable is goin through
08-21-2018, 07:56 AM | #4 |
Moderator
Thats the speedo cable hole. The clutch hole is egg shaped.
08-21-2018, 10:24 PM | #5 |
Thank you for the responding. I got the truck as a non running project so I never realized the speedo cable is missing. I guess I need to find a speedo cable once I get it back on the road.
08-21-2018, 10:55 PM | #6 |
Moderator
Looks like your missing a couple of holes. There could be good reasons for that I couldn't speak intelligently about that, but I'm sure there are people on here who could. Unless of course they were plugged and it was repainted.
08-21-2018, 11:36 PM | #7 |
60-66 Nut
The '60-'62 Chevy's and '60-'63 GMC's have hydraulic clutches so there is no hole in those floors for a clutch linkage rod. I'm thinking it is for the speedo cable.
