Old 08-25-2018, 01:38 PM   #1
C101971
Running rough
So I'm getting kind of clueless with this problem. My truck, 71 GMC c15 with a 350, runs super rough out of nowhere for no reason, at first I thought it was a spark issue, I replaced the distributor, plug wires and plugs. It ran great for a few seconds then rough again. Fuel maybe? So I checked my fuel filter, it is glass so I can see if there is no fuel, and sure enough, a lack of fuel. Bought a factory replacement and she ran great for a few days then back to square 1. Replaced all fuel lines, filter seems fine, it is a mechanical fuel plump and it seems to work fine, I don't see why it would break after a few days.
I moved on to see if the fuel sending unit gas line was clogged and it's clear. No vaccume leaks that I am aware of, the carb isn't even a year old, the new Holley street demon. Never had to tinker with it. Jets seem to work fine. I've replaced the whole fuel line and I'm completely lost.
The engine is timed, 8° past top dead centre. Harmonic balancer is a bit wobbly but I doubt that would cause the issue.
Any ideas? I just want my truck to work again...
C101971 is offline   Reply With Quote
Old 08-25-2018, 01:45 PM   #2
geezer#99
geezer#99's Avatar
Re: Running rough
Timing!
Do you mean 8 degrees before tdc? Or 8 degrees after tdc.
You likely need it at 16 degrees before tdc.
Especially at your altitude.
Besides the. Carb, what other mods.
Headers,cam?
Old 08-26-2018, 02:15 PM   #3
C101971
Re: Running rough
Originally Posted by geezer#99 View Post
Timing!
Headers,cam?
8 deg before is what I meant yeah. But it's been set at 8 for months, why would I need to set to 16 all of the sudden?
Old 08-26-2018, 02:17 PM   #4
C101971
Re: Running rough
Timing!
Headers,cam?
Stock headers, stock cam, only mods I have is valve covers, carb, intake manifold, water pump, radiator, rad fan, exhaust, distributor, plug wires, plugs, fuel pump. I think that is all
Old 08-26-2018, 02:23 PM   #5
Fbks_Cruiser
Fbks_Cruiser's Avatar
Re: Running rough
Clogged pickup in the fuel tank? You mentioned checking the fuel line from the sending unit but not the sock on the sending unit.
1972 GMC K2500 Super Custom
Matt
Fbks_Cruiser is offline   Reply With Quote
Old 08-26-2018, 03:32 PM   #6
C101971
Re: Running rough
Sock had some buildup in the corner but didn't interfere with the line. Will try a new sock
Old 08-26-2018, 03:37 PM   #7
geezer#99
geezer#99's Avatar
Re: Running rough
16 degrees because you should be at 16 degrees!
Have you looked in the carb to see if it’s flooding?
Old 08-26-2018, 04:42 PM   #8
68 P.O.S.
Re: Running rough
x2 on the timing. Which carb are you running? Which distributor?
72 C10 lwb fleetside -stock 350/350 combo
68 P.O.S. is offline   Reply With Quote
Old 08-26-2018, 07:29 PM   #9
C101971
Re: Running rough
The new Holley street demon and a msd distributor
Old 11-02-2018, 05:39 PM   #10
68 P.O.S.
Re: Running rough
Did you ever get this squared away?
