Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 08-27-2018, 11:00 PM   #1
jhngardner367
jhngardner367's Avatar
Timing set on an '02, 2.2
Does anyone make a tensioner eliminator timing set for the 2.2 l engine/
Igf so,has anyone used it,and how do you like it?
Always expect the unexpected,....but don't expect the unexpected to be the unexpected you expect !
I'm busier than a one-legged cat,in a sandbox!
Veteran..and proud !
I can't fix what ain't broke....you want I should break it?
jhngardner367 is offline   Reply With Quote
Old 08-28-2018, 11:12 PM   #2
jhngardner367
Re: Timing set on an '02, 2.2
Ok,so, I found a Cloyes timing tensioner eliminator set(C-3019ms ).
Reviews were good,so I'll try it.
The tensioners that Gm uses,are scary,to say the least!
