08-30-2018, 07:18 PM | #1 |
1/2 vs 1-ton panels - same rear bumper?
I have an opportunity to get a rear bumper, brackets and valance for my panel truck, but it's on a 1-ton (I think it's 1-ton, it has 8 lugs). Anyone know if the rear bumpers are the same as my 1/2-ton?
1951 Chevy Panel Truck |
08-30-2018, 08:43 PM | #2 |
Post Whore
Re: 1/2 vs 1-ton panels - same rear bumper?
Should be the same size wise 1/2-1ton..the trucks larger than 1ton used a different front bumper but im unaware of these big trucks having a rear bumper and pretty sure they didn't make a panel over 1ton
And the panel may be a little different than a pickup
08-31-2018, 11:33 AM | #3 |
If I recall, panels use a front bumper on the rear..
08-31-2018, 12:51 PM | #4 |
yes, same bumper 1/2 to 1 ton, i believe they may be the same as the front bumper
same basic frame, same width, biggest difference in 1 ton is straight over the rear axle. no axle bump panels use pickup frames and have rear frame extensions approx 1 foot, same for all panels
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
09-02-2018, 09:50 PM | #5 |
Well I spent the day crawling under a 1-ton panel truck removing the rear bumper and brackets only to get them home and discover that they are approximately 10 inches narrower than my 1/2-ton bumper brackets. WTH? $100 wasted, dang it. Here's a photo comparison :
09-02-2018, 10:00 PM | #6 |
Well I missed the thread earlier or I would have mentioned that and it is a wonder someone else didn't 3/4 ton and larger frame rails are pretty much straight all the way back from the front cab mounts to the back end while 1/2 ton spread out as you see.
09-02-2018, 10:55 PM | #7 |
$100 lesson learned. Grr...
09-05-2018, 08:00 PM | #8 |
MiraclePieCo;
How that you have the bumper just take the time to make your own bracket to fit the frame . Then you have a custom fit bumper. T-P Auto Tim |
