09-08-2018, 10:35 AM | #1 |
Bushings for Tailgate Hinge
The tail gate on my 53 Chevy truck fits quite loose (about 1/4" of play between the tailgate and the hinge. Am I missing a bushing that should go in the tailgate or meant to be loose on the hinges?
Thanks. Wade
53 Chevy 3100, SBC 355, 700R4, S10 frame, Ford 8.8 rear with 4.11 gears, front disc & rear drum brakes |
09-08-2018, 11:43 AM | #2 |
Re: Bushings for Tailgate Hinge
I know of no bushing, are the hinges or the gate reproduction?
Brian
1948 Chevy pickup Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats! Bought with paper route money in 1973 when I was 15. "Fan of most anything that moves human beings" |
09-08-2018, 07:09 PM | #3 |
47-53 use this style hinge
they may be worn slap out 54 to 80s used this style hinge
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
09-09-2018, 09:12 AM | #4 | |
Ogre, I have the 53 style hinges.
09-09-2018, 11:04 AM | #5 |
Trunnion. That's the technical term for the "hinge".
So when is this "Old enough to know better" supposed to kick in? My 1959 GMC build thread http://67-72chevytrucks.com/vboard/s...d.php?t=686989 |
09-09-2018, 11:46 AM | #6 |
Worn out or the hole in the tailgate is stretched out. You just have to take it apart and see what looks bad and either replace the part or come up with a way to take up the slack
They don't sell bushings but that doesn't mean you can't make a bushing or sleeve to take up some of that slack.
09-09-2018, 12:50 PM | #7 | |
Brian
09-09-2018, 06:25 PM | #8 |
I JUST bought the reproduction poly type trunnions for my ‘55.2 figuring they’d cause less rattling than the original metal ones. Plus they come with polished stainless buttonhead bolts that will look better.
But they made my tailgate fit slightly lower than the factory bedsides which would have resulted in chips happening faster on the tailgate “Hasps” (I guess they’d be called). i mean where the slotted tab on the tailgate mates with the bedside and the chain goes through. I hope that description makes some sense. I have no photo. Unfortunately this makes me have to use the factor plain carbon steel bolt for now. But I’ll swap them out for stainless eventually. We re-installed the factory metal ones coated in wheel bearing grease.
'55 Big Window Shortbed, Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's Dan's '55 Big Window "Build" - Well, Kinda! |
09-09-2018, 07:31 PM | #9 |
Post Whore
I made some bushings and hinges..I had to make new hinges anyway because one was homemade...
Different manufacture but may give you some ideas... I made them from uhmw...
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 09-09-2018 at 07:36 PM. |
09-09-2018, 07:46 PM | #10 |
Greg, you may get many inquiries on these. Looks like a good clean design.
