Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > FAQ Truck Tech > 67-72
Old 11-17-2003, 12:21 AM   #1
jorgensensc
jorgensensc's Avatar
INSTALL: Tennman's Sidemarker Fuel Fill on a Stepside
Finally got around to showing the install! I hope this helps everyone. There are alot of pics, so it might take awhile to load them all.
Here is what I used:
1- 1997 S10 fuel filler door with neck
1- 1 1/2 fuel filler hose (see blazer tank install for part number)
3 ft of 5/8" hose
4- 1/4" machine threaded bolts 1 1/4" long
4- nylon lock nuts for above bolts
2- 1/2" spacers for above bolts
1- permacap gas cap (optional)
1- large can of patience!!!
Here are the parts I got from the local wrecking yard:
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline
