Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 09-20-2018, 04:49 PM   #1
K5 MAX
K5 MAX's Avatar
Project Gumby Phase 1
Bought my first K5 on Valentines Day this year. Here's the its introduction thread http://67-72chevytrucks.com/vboard/s...d.php?t=757258. Details: 72 K5 350/350, 4x4, P/S, white top, heavy duty radiator, posi, base model i believe. Pretty much original from what I can tell, everything there but the back seat and well half the top. Drove it up on the trailer despite a seriously rusted out gas tank.
This will document my "Phase 1" build. First step is a new 87-91 K5 gas tank so i can drive it more than 15 yards without worries of it dying. Plans are to get it road worthy and reliable enough for me to enjoy it around the house and occasionally drive it to work. Body bushings while the tanks out, install 00-06 seats front and rear, remove the homemade half top, install a soft top, maybe attempt some rust repair. We shall see...
When I bought her
IMG_0795
1972 K5 Blazer
350/350/PS/PB
From GA but live in Panama City, FL
K5 MAX is offline   Reply With Quote
Old 09-20-2018, 07:49 PM   #2
jeffg1010
jeffg1010's Avatar
Re: Project Gumby Phase 1
along for the ride!
Jeff
1972 Blazer CST 2wd- My son Sam's Project "S" Project "S"
1970 Suburban - SOLD "One Bad Burb" Photobucket Album
1986 C30 Crewcab - 63K original miles, original paint
Members I have met: mikey531, gcburdic, bashed, burbman69, TonyPieras, Blazester, GCncsuHD, custombuilt67-72, tsnow678, highrpm, PanelDeland, tanman722001, 47thriftmaster, babyblueoval, 68stepbed, JesseWebb, Andy4639, xs-style, TobyArnot, BigOrange, frednoah, brn_agn, k5hart, Graham57a, bhelton, AJohn6, SilverC10, 69CST, '71 Flame, RaceAGMC, Liz, Josh, MattPSU, 68corvair, Chevy350V8, mdeal, ccrorymc, mrhurt73, dmxxpert, Custom68, 84GMC, BionicABs1, BigBlockBurris, Ebfabman, ATP...
jeffg1010 is offline   Reply With Quote
Old 09-20-2018, 11:03 PM   #3
K5 MAX
K5 MAX's Avatar
Front 01 suburban seats to go in, they've been seriously cleaned now
44
Back seats to go in, got the factory hold down attachments out of the same vehicle 42
Used Softopper off CL
46
45
Time to remove the homemade half top, apparently somewhere along the way the top was damaged by a tree so they cut it down and made a half top, had a pickup slider back window in the back wall
32
33
34
35
Tops off!! Set up for pressure washing the under carriage, so nasty under there
51
My son / helper-Maddux, 1 yr old
53
1972 K5 Blazer
350/350/PS/PB
Old 09-20-2018, 11:33 PM   #4
K5 MAX
K5 MAX's Avatar
Gas tank out, before pressure washing though
47
Mostly surface rust
11
Old tank, cut the filler neck off because I wasn't sure how the 87-91 was gonna work. Didn't end up using it though. Was able to make the 87-91 work without modifying or reusing the old filler
12
Rear frame horns have been cut off for the homemade bumper that's on it. Oh well I actually don't mind the look of the bumper they built
14
1972 K5 Blazer
350/350/PS/PB
Old 09-20-2018, 11:43 PM   #5
K5 MAX
K5 MAX's Avatar
Removed the 4 rear body bolts and bushings (#2-#5) on both sides (loosened #1 under the floor boards) so I could clean the frame and body mount locations to prep for POR15 before the new body mounts and tank goes in. Gonna try to do the frame paint in sections because I don't plan to pull the body off until the full restoration happens down the road. Blocked the body so I could get to everything
My method to get the body up to block it
75
76
61
62
63
Had to remove the bracket (at the frame) that held the rear flexible brake line to the top of the axle, it was in the way of the new 31 gallon tank
64
1972 K5 Blazer
350/350/PS/PB
Old 09-20-2018, 11:55 PM   #6
K5 MAX
K5 MAX's Avatar
Wire wheeled everything clean that I was gonna paint, cracks in the passenger far rear body mount box, will be welded up the best I can (still learning) obviously the holes in the bed floor will need addressing but that can wait
55
Cracked on the other side too, on the bottom
56
Bought all three steps from POR15; their degreaser, metal prep and satin black. Got the rear frame coated (bottom, inside the frame and top) from the axel back basically. I'll do the outside later with the wheels off. Hit some rusty spots on the underside of the body, bumper and in the rear channel under the bed to try to stop it from getting worse
72
73
70
69
68
67
65
66
Cleaned up the rear tail light wiring harness of some hacker wiring and re-taped it before going back in
74
87-91 gas tank is fully mocked up, gonna write up a separate thread to make it easier for others to find later. I put the link here as well. I searched and searched an had a hard time finding a complete detailed write up. Found some good info on some of your build threads, just took a lot of time. I'll put the tank in for the final time tomorrow and hopefully get her cranked this weekend! Excited to drive her more than 15 yards and to cruise with the top off. We'll see what demons rear their heads during the drive. Pretty sure the brakes will need some work. Thanks for looking!
1972 K5 Blazer
350/350/PS/PB
Old 09-21-2018, 12:26 AM   #7
1rippen6
I have the rear frame horn pieces to fix what you are missing. If interested pm me your email or cell number and I can send you some pictures.
1rippen6 is offline   Reply With Quote
Old 09-26-2018, 11:40 AM   #8
K5 MAX
K5 MAX's Avatar
Finished #1-#5 body bolts and bushings, #1 was a booger to get out without cutting the floor too bad because its down in that depression. Went with the LMC rubber kit, because i needed bolts also. When the body comes off later during another phase of the build i'll prob go poly for the mounts at that time
83
Cleaned up and painted the mounts, factory shims while #1 bushings were out
84
85
Mine had 2 factory shims per side in the #1 location
86
Painted the body bushings, seemed to be bare metal to me, trying to prevent future rust
82
Had to weld a large washer onto the #5 body bolts because one side was roached out in the body bolt hole area
79
Did notice that the #4 top body bushing didn't sit down into the hole once tight, almost like the round spacer they provided with the kit to keep all the rubber from compressing too much was too long. Anyone else had this problem?
115
1972 K5 Blazer
350/350/PS/PB
Old 09-26-2018, 04:28 PM   #9
K5 MAX
K5 MAX's Avatar
separate thread on the 87-91 gas tank install
http://67-72chevytrucks.com/vboard/s...d.php?t=772117
1972 K5 Blazer
350/350/PS/PB
Old 09-27-2018, 09:40 AM   #10
K5 MAX
K5 MAX's Avatar
After driving her a little a few issues have arose..leaky master cylinder out of the lid
And leaking out the radiator drain plug, gasket is dry rotted
Few more vehicle pics
Drivers kick panel rust, the front roll cage is welded directly to it, no plate or support underneath. I'll be taking the roll bar and front cage out soon
Roached out at the top of the passenger bedside, looking for a patch for this. Its weird the rust is worse on the passenger side vs the drivers. maybe the way it was sitting somewhere during its life. like one side got more weather or never was able to dry out from the sun or something
Passenger side windshield frame rust......
1972 K5 Blazer
350/350/PS/PB
Old 10-04-2018, 03:55 PM   #11
K5 MAX
K5 MAX's Avatar
Almost done with the 01 Suburban power front seats install, few pics
Cut the front mounts off the seat tracks
Marked and drilled a 1.5" x 1/2" "C" channel for the factory bolt hole locations
Set seat in place, marked then welded the tracks to the "C" channel, did have to clearance the tracks slightly to clear the welds
Idea of how they will look, front cage and roll bar are coming out, they prevent the seat from reclining like I want. Plans for a full cage later that will work better for my set up
1972 K5 Blazer
350/350/PS/PB
Old 10-08-2018, 06:35 PM   #12
warrpath4x4
looks like some fiberglass on the floor there too by the seats
1972 K5
warrpath4x4 is offline   Reply With Quote
Old 10-09-2018, 02:12 PM   #13
K5 MAX
K5 MAX's Avatar
Yeah the POx2 did patch jobs everywhere there was rust before the guy I bought it from bought it....
1972 K5 Blazer
350/350/PS/PB
Old 10-13-2018, 10:31 AM   #14
raggedjim
raggedjim's Avatar
I hope you came through the hurricane okay. I'm going to go with 503 on the jimmy I'm letting gather dust... If you still have the old tank would you like to sell the filler neck off of it? Let me know.
Rg
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
raggedjim is offline   Reply With Quote
Old 10-19-2018, 11:28 PM   #15
K5 MAX
K5 MAX's Avatar
Rg
Thanks for posting. My home was affected by hurricane Michael but I fared better than a lot of people so I can’t complain. Roof felt and shingle damage, and storm surge in my non living areas. My shop / storage where the K5 was sat 11’ above sea level. The surge came in enough to buckle a hurricane rated garage door like it was nothing. Then proceeded to blow out 2 walls in my shop. Pushed the K5 4-5’ forward. It took on 3-4’ of water but it didn’t reach the air cleaner or dash. All the interior was already out so I hosed it out real good, under carriage as well. Still had to drain and refill all the fluids from the purchase so that’ll get done sooner rather than later now. Pretty much a total loss on all my tools down there. Dealing with insurance companies now. Luckily I had flood insurance. I do have the filler neck cut off the old tank. Shoot me a pm with your email and ill send ya a pic of it. Build will loose some steam bc I have to focus on house items now. Sucks
1972 K5 Blazer
350/350/PS/PB
Old 10-24-2018, 12:03 PM   #16
raggedjim
raggedjim's Avatar
Sounds pretty bad to me. I sent a pm with my email. I know you are probably busy so no big rush.
Rg
Roger
'70 GMC Jimmy 2wd
