Old 09-29-2018, 08:50 PM   #1
FAKKY
well im an idiot....
LS Oil pan swap.
Was having problems with my torque wrench for some reason ......... think it was the angle.
I overtightened the oil pickup tube 10mm bolt and snapped if off ..... so mad at myself as usually Im really careful with that stuff in aluminium
What are my options here ? ........
FAKKY 57 PANEL BUILD
FAKKY is offline   Reply With Quote
Old 09-30-2018, 01:15 PM   #2
FAKKY
Re: well im an idiot....
Git out .....
Old 10-01-2018, 08:12 PM   #3
AussieinNC
Moderator
AussieinNC's Avatar
Not sure but that snapped bolt does not look correct...with that turned down end it most likely bottomed out in the bolt hole before clamping down fully....
Check the bore threads in the block for damage
Double check the depth of the thread needed and make sure bolt is not too long
I always dry assemble first then back the bolts out and apply thread locker to each bolt
Tighten to 106 in pounds....
Thats inch pounds
Lucky you got the broken piece out ok...
Good luck
Family and country before all others...
2006 Chevy Silverado (Daily Driver)
2012 Chevy Equinox
AussieinNC is offline   Reply With Quote
Old 10-01-2018, 08:55 PM   #4
FAKKY
Not sure. But it could have bottomed out by over tightetning.
Have another one in the head (not my fault this one) on exhuast manifold. What do you think - use a weld/nut or try the same appraoch with left hand drill bit.
See the "Eagles V Collingwood" yes Sir.
Old 10-02-2018, 08:46 PM   #5
AussieinNC
Moderator
AussieinNC's Avatar
If the bolt in the exhaust manifold is in the head it should be center drilled and a stud extractor used to remove the broken stud....
While you are at it, replace all the studs / bolts with new ones and make sure you use anti sieze on the threads when re-installing them...
Eagles v Collingwood...nah...I am Sydney born...more likely yo be Eels v Rabitohs....
Where you at mate?
2012 Chevy Equinox
Old 10-02-2018, 09:10 PM   #6
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Here is a thread where I removed the broken exhaust manifold bolt on the LS in my '06 Silverado K2500 HD. Hope it helps.
http://www.67-72chevytrucks.com/vboa...d.php?t=587659
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 10-05-2018, 04:39 PM   #7
FAKKY
Where you at mate?
St Petersburg - FL ...... originally from Perth.
Old 10-05-2018, 04:40 PM   #8
FAKKY
Gary
Awesome gary - thx
Old 10-06-2018, 12:53 PM   #9
FAKKY
Curious minds gary.
Tried the easy out/left hand drill bit - no beuno on this one either.
So going to try weld.
Why does the weld not stick to the aluminium block though - I know its mig/steel wire not aluminium wire ....... but still thought it would try and stick and potentially the damage the threads etc.
Old 10-09-2018, 10:18 PM   #10
4Robinsons
I have luck by plug welding a flatwasher to the broken bolt n then tackweld a nut on in place and then plug welding that mainly cause you can see the broken bolt and get a good well to it with washer then can weld nut solid to washer easier than to small bolt...I've just found this to work for me as working on big trucks every day I run into broken bolts often
4Robinsons is offline   Reply With Quote
