Hazards not working
Where do I start to get my 1971 C10 hazard lights working all the other lights turn signals brake lights reverse lights work?
Re: Hazards not working
Perhaps the flasher?
Stupidity was meant to be painful! |
When i turn on the hazards on turn signal don't work. I haven't tried anything yet but wondering if they need to be bypassed. Any idea's where i should start? All other lights work.
![]() Join Date: Dec 2015
Your flasher is definitely the problem. Replace it and everything should work just as designed.
My Paypal address is: http://paypal.me/KFerguson66 72 K20 Cheyenne Super My "re-build" thread http://67-72chevytrucks.com/vboard/s...?t=710221&goto Thread for my Reproduction Jack Bags http://67-72chevytrucks.com/vboard/s...d.php?t=715455 |
Ouch.....im a newbie
like others have said, replace the flasher, there is one just for the hazards
I replace the flashers that hazards work but my reverse lights are not working does that come from that same flasher as well as the horn
Did your horn work before you replaced the flasher?
Your reverse lights work from a switch on the steering column. The flashers have nothing to do with you reverse lights or your horn. If you are having new issues after replacing a flasher then you have bigger problems than just a flasher not working. Do the hazards work after replacing the flasher?
