10-16-2018, 08:45 PM | #1 |
NEED some WAGS( wild as
s guesses)......
'72 350 with HEI in my K/5......not a DD at all....so I start it up frequently and drive it when I can.... Last Thursday..started up, warmed up...shut it off.... Friday afternoon....went to start and drive....two or three, what sounds like backfires, and the starter hung up in the flywheel.....got that fixed.... tried to start up..... same thing a few backfire sounding noise...but no start... I'm thinking....best case.....ignition module? worst case....jumped time.....tomorrow I will pull the cap and check for that I have no history of this motor...except that it's been running like a champ until now....
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. Last edited by A1971Blazer; 10-17-2018 at 06:20 PM. |
10-16-2018, 09:19 PM | #2 |
Re: NEED some WAGS( wild as
loose rotor in dizzy?
Wires arcing together? |
10-16-2018, 09:43 PM | #3 |
It doesn't sound like a module to me, but it could be that it jumped time. Possibly also arcing inside the cap - I've had that happen before.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
10-17-2018, 10:58 AM | #4 |
Active Member
As above, I'd start with ignition. HEI cap and rotor first then check timing with #1 piston at TDC on compression stroke and timing mark lined up with timing tab. Then cross firing or arcing of spark plug wires. If that's all good it's really a "WAG" until you do a compression check on all cylinders.
If all checks above are good and if you have a quadrajet check for leaking well plugs. There will be a pooling of fuel in the intake that can cause backfiring and it's a known problem.
68 GMC 250/3 speed Saginaw p/b p/s 69 Chevy 350/350 currently in pieces still lookin for a cab 06 Trailblazer I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive... |
10-17-2018, 06:19 PM | #5 |
I'm happy to report....the noise that sounded like it was backfiring....
as it turns out...the culprit is the starter....
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. |
10-18-2018, 12:14 PM | #6 |
Active Member
Since we assumed it was backfiring, I guess you did get some "wags".
Glad you found the problem, though. Do you know what exactly the problem is or are you replacing the starter/solenoid complete? Might help someone else in future diagnosis.
10-18-2018, 12:27 PM | #7 | |
I got it loose and then I got my buddy to crank it over while I was underneath that's when I figured out it was the starter making the noise.....it's looks to be kicking away from the flex plate.... It will start up now..... so I'm gonna move it into the shop and put it on the lift.....(I hate laying on the floor working on a starter) so I can do some closer inspection...it's likely that it isn't shimmed correctly or the starter head is weak or cracked. I went ahead and ordered a new starter today, along with new bolts and some shims...also plan on putting a rear brace/bracket on it as well.... and thanks for the WAGs...
10-18-2018, 12:28 PM | #8 |
Let me guess it was the starter. :-)
(Very) Slow-Going Build Thread: Stock 1970 Short Step with Stock 1970 LT-1 http://67-72chevytrucks.com/vboard/s...d.php?t=567340 |
10-18-2018, 12:54 PM | #9 |
Hey.....that could be it...
On an unrelated topic I see in your signature "1970 LT-1" My buddy's Dad used to own a Chevrolet dealership years ago...we would go in at night and add our hot rod parts to the parts man's order...back then.....a brand new, complete LT-1 short block was $325.00 dealer cost...we bought a few....wish I still had them....!
