small back window glass
can anyone tell me the original rear glass thickness on a small back window 2nd series
I need really close measurement please thanks in advance |
Re: small back window glass
It is not flat like older trucks, so if you were going to have one cut I don't think it would work.
Mine is out and measures at exactly .25", however, as stated, the glass is not flat, but rather domed.
Cheers, Jim |
#4 | |
its a street/strip truck that is getting lexan so itll easily bend and flex if needed |
But laminated glass does flex some. I know I have put flat glass in a 56 I chopped years ago, not a problem.
Brian
1948 Chevy pickup Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats! Bought with paper route money in 1973 when I was 15. "Fan of most anything that moves human beings" |
I think the key word here is "domed". It is curved in both directions which would be hard to achieve with a flat piece of plexiglass.
#8 | |
Brian
Yeah the curve is only slight so I could see where a flat piece could probably work. I didn't realize they are curved until I pulled an original one from a parts truck I had.
The rubber gasket will flex some, and glass can flex some, but when the glass is flexed it has stress and will brake easy.
#11 | |
Brian
