Old 11-07-2018, 04:46 AM   #1
Slow Build
Slow Build's Avatar
Tire load index # for 2005 Sierra?
I tried to get a nail hole patched at America's Tires locally and was turned away because, according to him, the 106 load index tires on my truck are unsafe for my vehicle and that it calls for a 108 load index tire. I came home and searched the internet trying to find a minimum load index # or any O.E.M. # for my truck and come up empty. It's not on the door jam either, just size and pressures. Where can I get this info? Also if this is some law/rule that they are following I would like to see it in writing someplace.
2005 GMC Sierra 1500 crew cab 2x4 short bed.
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline   Reply With Quote
Old 11-07-2018, 09:39 AM   #2
95 S_Trucker
95 S_Trucker's Avatar
Re: Tire load index # for 2005 Sierra?
The load rating for a standard 1500 is 108
The load rating for a 1500HD is 120
106 is rated for 2094 pounds per individual tire.
108 is rated for 2205 pounds per individual tire.
You are realistically safe, but not legally safe.
You may be able to get your tires replaced if they were installed/sold to you by someone that will stand behind their work. It is unlawful to put underrated tires on a truck(or car), but it happens all the time(people changing sizes). Its an item I have to check when I inspect cars in my shop(PA Inspection)
Or you can go to a NON chain/franchise place to get your tire fixed.
95 S_Trucker is offline   Reply With Quote
