Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1973-1987 Chevrolet & GMC Pickups Parts Board
Old 11-08-2018, 07:11 PM   #1
Baketown Scotty
Junior Member
Baketown Scotty's Avatar
WTB - Cross Member for NP208
I need a cross member for supporting a NP208 behind a 700R4 in 1969 K5 Blazer. I "think" one from a 1985 GMC K3500 may require the least modifications to work. Thanks.
1964 Chevy Suburban 4x4
1966 GMC Suburban 4x4
Baketown Scotty is offline   Reply With Quote
Old 11-10-2018, 08:59 AM   #2
GonicGM
GonicGM's Avatar
Re: WTB - Cross Member for NP208
The adapter style will define crossmember requirement. Using a 81-84 tall adapter should allow usage of an original 69-72 style crossmember, easiest. Using a 85-91 short adapter will require spacers or a different crossmember. I have a 81-84 tall adapter for TH700R4 to NP208 available.
83 K30 SRW 350 TH400 NP205 4.10 9' Fisher
85 K30 SRW 350 TH400 NP205 4.10
87 V3500 Dually 454 TBI SM465 NP205 4.10 9' Fisher
83 K2500 350 TH700R4 8600GVW Dual Tank 4.10
1973 Cheyenne Super 30 DRW Std Cab Z83 4.10
1976 Silverado C30 Std Cab 4.10 DRW (4 sale)
GonicGM is offline   Reply With Quote
Old 11-13-2018, 06:35 PM   #3
Baketown Scotty
Junior Member
Name:  T-case support(2).jpg
Size:  54.5 KBThank you for the response GonicGM. I think I would rather go with a different cross member. I have a home made spacer in there now. I'm trying to get rid of my 3'' body lift. The reason I put that in to start with was when I swapped out the NP205 for the NP208, the NP208 sat up higher. I plan to drop the NP208 an inch or so and add a skid plate under it.
Old 11-23-2018, 01:35 AM   #4
Jsfucttruck
I got a cross member from a 86 Burb that had a 700r4 and a 208.
Located in Santa Cruz Ca
Jsfucttruck is offline   Reply With Quote
Old 11-28-2018, 12:36 AM   #5
Baketown Scotty
Junior Member
Jsfucttruck - Would it be possible to get a picture of your cross member and maybe some dimensions? Thanks
Scot
