11-18-2018, 09:06 PM | #1 |
1968 C10 with coil springs, how to....?
My 1968 C10 does not handle loads very well, so I would like to beef it up some, not necessarily lift the rear end, just beef it up some.
Any ideas? Rick |
11-19-2018, 12:06 AM | #2 | |
The Older Generation
Re: 1968 C10 with coil springs, how to....?
Some trucks had factory option helper springs. They come up for sale on the parts boards every once in a while. Here are a couple of pictures of them. The rear frame rails have been cut off in the second picture so it looks out of proportion. LockDoc
11-19-2018, 01:42 AM | #3 |
Here's a better view of the one in the picture of my '69 C20 frame that LockDoc posted above.
11-19-2018, 03:12 AM | #4 |
I had the same issue with my '70 C10. Replaced the old stock coil springs with heavy duty progressive load coils & that did the trick!
1970 CST long bed Fleetside |
11-19-2018, 06:41 AM | #5 |
11-19-2018, 07:23 AM | #6 | |
Old member
http://67-72chevytrucks.com/vboard/s...d.php?t=688743
11-19-2018, 08:47 PM | #7 | |
1970 C10 8' Fleetside, L6 250, 3 on the Tree. The most basic of pickup trucks! |
11-19-2018, 09:37 PM | #8 |
Lots of options here: https://www.truckspring.com/Search.a...n-Parts&page=1
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
11-19-2018, 09:39 PM | #9 |
I am doing a modest 2 1/2 front - 3" rear drop will the overload springs work with this drop or will I need to do something different? Maybe a pair of flatter leaf springs taken out of a car, cut and drilled to fit? Not meaning to hijack thread just thought it may be relevant.
11-20-2018, 10:41 AM | #10 | |
https://www.earlyclassic.com/catalog...=139&keys=rear I also used these shock mounts to keep the shocks more vertical with shorter springs. Very important if you want the shocks to actually work! https://www.earlyclassic.com/node/1194 Doesn't look like they sell heavy duty drop springs, but they might be able to point you in the right direction. Call them at 888.777.0395.
11-25-2018, 12:16 PM | #11 |
Hey Rick, I was just wondering if you had made a decision on what to do with the back of your truck. I've got a 67 shortbed with the same issue. Thx, mike
11-25-2018, 12:57 PM | #12 |
To the OP: Moog #6101 springs should increase the load carrying capability without raising the truck up too much.
Concerning a rear drop AND increased load handling, I'd try lowering springs because they are typically stiffer than stock std duty springs. And if they can't handle a load, then take a look at the helper springs mentioned above or an Air Lift kit.
