18"/19" Wheel Choices
Hey guys, I am looking to buy a set of 18" or 19" wheels for my 68' but I'm having a hard time finding a set I like in my price range. I was hoping to keep the cost of the wheels under $350/wheel.
Currently the truck is 6 luck and stock drum brakes. I have a rear 5 lug set of discs/calipers to go on eventually when I have the money to buy the drop spindle/disc brake conversion fronts. Varrstone has a set I really like (ES9B), the problem is the offset is not ideal. It has a +12mm offset and I would need some massive (2-3") lug conversion spacers to run them. a -12 or -20 offset would work much better for the current drum brake setup. ![]() Obviosuly Forgeline makes some really nice wheels that I like as well, but spending $1600 per wheel is not in my budget. If you guys have any brand/manufacture suggestions that may have a wheel similar to whats shown above, it would be greatly appreciated. -Ryan |
Almost Satisfied
![]() Join Date: Mar 2002
Re: 18"/19" Wheel Choices
About every wheel I like is in the neighborhood of $800 - $1,000 per wheel. Just not going to spend that kind of money. Billet Specialties has some nice wheels in your price range. I have also looked at a few of the American Racing wheels. Foose has a couple that are $200 - $300. Good luck and let us know what you go with.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021. "I can't complain, but sometimes I still do. Life's been good to me so far." |
I had orignally planned to buy the varrstone wheel and just run lug conversion adapters but after measuring I would need 2" up front and closer to 3" out back. That gets a bit scary to me.
I'll have a look at billet specialties. I forgot they make more then just drag wheels. -Ryan |
Old member
I know these are not 18-19 but craigslist is a good place to look for nice wheels cheap.
These are cheap enough as well. $350 call 864 353 4857 ![]() ![]() ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Thanks Andy, I have a set of transport wheels that I was originally planning to use. They are just slightly too big and too heavy for my taste. I was hoping to find something a bit more modern.
#6 | |
Old member
![]() Quote:
Just a friendly reminder. ![]()
That's what I am looking for.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
![]() Join Date: Jul 2018
If your going to drop 350 on a wheel, coys and us mags both make some good looking wheels but they are 20”. Both look great in a 45/50 series tire
Posted via Mobile Device |
I'm looking at these, not sure about the width fitting but I think they come in 18"-19"
Moto Metal MO98329050312N - Moto Metal Series MO983 Dagger Gloss Black Wheels with Milled Accents
2003 Dodge 2500 1969 C10 2014 Camaro SS/RS/1LE |
I found these today while looking through another board members build thread. These are one of the better looking wheels I could find with a decent offset to them.
Ridler 650: ![]() They come in 18x9.5 with a zero offset, or 20x10 in the same offset and 5x5 lug pattern. |
I thought about those also, but have seen a lot of them on trucks already. Still want something different, just can’t afford my taste.
#13 |
I was surprised to find Billet Specialities has an affordable rim. And I even like how it looks. They start at $210/rim.
http://www.billetspecialties.com/whe...ies/speedway-/ ![]() ![]() ![]()
1972 Cheyenne Super SWB PS, PB, Tach, A/C, Tilt. Drivetrain: Built 402BB, TCI Streetfighter 700R4, 2,500 stall, Eaton posi, 3.73. Suspension/Chassis: ECE 4.5/6.5 drop, CPP nitrogen shocks, CPP front and rear sway bar, CPP cross members. Exhaust: 3" exhaust with x-pipe, Spintech 3000 mufflers, Hooker ceramic coated headers. Best 1/4 mile time: TBD. |
#14 |
http://us-mags.com/wheels.cfm
http://www.rocketracingwheels.com/ https://www.americanracing.com/wheels/6640/heritage-1pc
