11-23-2018, 04:07 PM | #1 |
Active Member
1968 manual column shift backup lights switch problem
My 68 backup lights did not work and I found out the switch was broken. This truck has the original column and never has been touched. I removed the switch and looked on the internet for a replacement like the one I took off but couldn't find one. (Below is a couple of pics)
I checked with O'reilly's and they said they had one that would work. I went and got it but couldn't get it to work. The one I took off has a single spring loaded post that looks like it is pushed when going to reverse and springs back when not in reverse. The replacement is a larger non spring loaded sliding switch. Anyone have any ideas on a replacement?
68 GMC 250/3 speed Saginaw p/b p/s 69 Chevy 350/350 currently in pieces still lookin for a cab 06 Trailblazer I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive... |
11-23-2018, 06:52 PM | #2 |
Active Member
Re: 1968 manual column shift backup lights switch problem
Update.
Did some more searching on the internet and found the switch I was looking for. The original part number was GM 3745921. I found one on this site: https://autopartsobsolete.com/1958-7...m-3745921.html
11-23-2018, 07:55 PM | #3 |
LMC has it in their catalog without a picture. I called them and they Emailed me a picture.
1970 C10 8' Fleetside, L6 250, 3 on the Tree. The most basic of pickup trucks! |
11-24-2018, 12:54 AM | #4 |
Active Member
Did it look like the one in the pics I posted?
11-24-2018, 12:37 PM | #5 |
Can you take them apart and use the spring in the new one? Just thinking even though it hurts to do so. Good luck.
11-24-2018, 08:24 PM | #6 |
Active Member
No. They're totally different. The O'reilly's is for automatic (powerglide, etc.) The one I need is for manual three speed and went ahead and ordered it from the site above. Should be getting it next week. I am keeping the O'reilly's since I have a complete steering column for my 69 that was automatic.
11-25-2018, 07:43 PM | #7 |
Exactly the same.
11-26-2018, 03:30 PM | #8 |
Was it number 36-0661 in their catalog? I need one also.
Stupidity was meant to be painful! |
