Old 12-02-2018, 08:20 PM   #1
rcazwillis
Gauge Cluster Chrome
The chrome on Zane's gauge cluster is badly faded. After researching here and on the web, decided to wrap it with chrome wrap. Turned out better than I expected. The wrap was easy to work. Had to learn to stretch it to get the wrinkles out.
Painted the gauge needles with Tester fluorescent orange. Another good tip from the forum.
Still may paint the black.
Zane's 71 Build
rcazwillis is offline   Reply With Quote
Old 12-02-2018, 09:54 PM   #2
External
External's Avatar
Re: Gauge Cluster Chrome
Chrome wrap?? Like what they use on the outside of cars?? Where did you get the stuff?
'72 Chevy Custom Deluxe Highlander. Med Olive/White 350/200 ps,pb and Air Conditioning!
External is offline   Reply With Quote
Old 12-03-2018, 01:07 AM   #3
dmjlambert
dmjlambert's Avatar
How do you do this? Any pictures to show or products to share?
dmjlambert is online now   Reply With Quote
Old 12-03-2018, 09:47 AM   #4
rcazwillis
Yes, same stuff used on car exterior.
https://www.amazon.com/gp/aw/d/B072Q...op_mb_pd_title
Zane's 71 Build
Old 12-03-2018, 11:04 AM   #5
davepl
davepl's Avatar
Cool though I'd like to see some pics of the work and result!
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 12-03-2018, 02:12 PM   #6
rcazwillis
The top pic was the finished gauge, but does not show the wrap. I will get a better pic tonight.
Zane's 71 Build
Old 12-03-2018, 10:06 PM   #7
rcazwillis
The finished product is good, not perfect. For $12, works well for me. Took some close up pictures.
To get a smooth finish on the corners, you have to stretch the material. It starts to lose it's shine if you stretch it too much. I cut a piece of material bigger than the entire gauge panel. Then stretched it over the sides. Once the wrinkles were stretched out, I trimmed it around the chrome edge to remove the center piece. On the back side, I just trimmed the excess off and did not worry about wrinkles.
For the gauge edges, I cut a 1" or so strip and worked it around the inside edge. The taper of the edge made the material want to not follow the inside perimeter. This required stretching the material as it is applied. There is a seam doing it this way. May be able to cut a circle out and stretch the inside to fit. This may require stretching it more than it is intended.
If I was doing it again, I would cut a 2" or so wide strip long enough to wrap around the outer perimeter. Then work it around like tape.
Edit: Just noticed the numbers 717 written on the back of the piece. That is not something I wrote. Must have been on their when built.
Zane's 71 Build
Old 12-04-2018, 08:53 AM   #8
I knew they made product for car modeling, but that stock is small. This looks great as far as looking chrome... looking like original. Got a picture straight on of the whole thing? Were you able to do the outer edge in one piece? So it shrinks and stretches for compound curves?
Old 12-04-2018, 08:57 AM   #9
rcazwillis
Not sure how to shrink, probably heat applied properly. Stretch was easy and covered the outer corners well.
Zane's 71 Build
Old 12-04-2018, 08:30 PM   #10
El Dorado Jim
looks great
El Dorado Jim is offline   Reply With Quote
Old 12-05-2018, 02:30 PM   #11
External
External's Avatar
Wow!!! Thanks for the up close pictures and the know how!!
Old 12-08-2018, 04:15 PM   #12
72bowtiestepper
Looks Good ! I like cheap improvements that I can do myself...Thanks for posting !
72bowtiestepper is offline   Reply With Quote
