Old 12-07-2018, 06:47 PM   #1
hugger6933
71 C-30 n o crank after sitting
71 one ton been sitting since 15 and now wont crank. engine turns by hand all the way all the plugs were pulled to replace. Gas line is removed at the tank waiting on new sender. I replaced the tank so I thought while waiting on the sender it would be a good time to turn the engine over a couple of times to work out the wd40 I put in the cylinders. I put on the battery and no crank I thought my dad was the problem, and after I talked him into mashing the clutch[but he argued that he was in neutral] until I reminded him of an invention of a neutral safety switch he then pushed in the clutch. Still no crank The headlamps came on so the battery had contact the battery tester show over 12.5 volts in the battery. Guess I'll start by checking for power at the solenoid. Jim
hugger6933 is offline   Reply With Quote
Old 12-07-2018, 06:59 PM   #2
Mike C
Mike C's Avatar
Re: 71 C-30 n o crank after sitting
Start by wiggling the steering column where the shifter is attached while you are turning key to start. Sometimes the interlock acts wonky when everything else is ok. After that you just have to start trouble shooting with a meter.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 12-07-2018, 09:26 PM   #3
Boog
laying low
Boog's Avatar
Jim it could be the old starter. You could try jumping it across the posts on the starter to see if it will engage that way and back track it. Sitting is the worst enemy of old vehicles. Things tend to corrode and stick.
We had an old B model Mack truck that sat for a few years and wouldn't turn over. The old starter had rust build up inside. The guy thought the motor had seized up.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 12-07-2018, 09:44 PM   #4
hugger6933
The shifter is in the floor it is a granny low 4 speed. I figured on checking the starter with a test light or starter switch
Old 12-07-2018, 10:36 PM   #5
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: 71 C-30 n o crank after sitting
Check the coil wires and see if it's getting fire.
If you tuurn the key and don't get anything I'd start with the key switch and make sure it's getting power.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 12-08-2018, 12:38 PM   #6
hugger6933
Well Andy, I have not got far enough to check coil fire cause it wont turn over no starter engagement.
i told my dad I wasn't worried about the dist fire if it didn't E-bay has a complete HEI with wires for $60.
I will when I go back to the shop check fire going to the starter then go from there. I forsee a starter pulling in my near future.
I was just trying to get it up and running and driving again to sell and it may turn into more of a project than I hoped. I hav e a 68 GMC that has been sitting about the same amount out time that is next on the list to get up and going. I also have a 68 tC-10 that has been sitting for lots longer that may be more of a challenge
Old 12-08-2018, 07:04 PM   #7
Mike C
Mike C's Avatar
If you have to get a starter, buy one of the GM style gear reduction mini-starters. Less weight, more power, less susceptible to heat soak. Money well spent.
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 12-08-2018, 07:16 PM   #8
hugger6933
Isnt the nose for the granny low trans different than the autos? I have some later model vortec type starter 96-98 that is the gear reduction type, but I am think the man trans starters bolt to the bellhousing not the block. Or at least the 70 v-8 with the3oot was.
Old 12-08-2018, 09:41 PM   #9
Mike C
Mike C's Avatar
Yes, they are a bellhousing mount starter. On my Jimmy I run a non-supported front mini starter that works great with the SM465 and the cast iron bell. The Hitachi style. Highly recommended if you can't use the GM one.
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 12-09-2018, 08:17 AM   #10
terry b
terry b's Avatar
Put a chain on it and pull start it. You can leave the key off for while it you want to build oil pressure before you start it. Then you can drive it around and warm it up and put it on some ramps to check the starter.
terry b is offline   Reply With Quote
