Old 12-07-2018, 07:15 PM   #1
HIGHWAY BY THE SEA
HIGHWAY BY THE SEA's Avatar
Brake switch mystery...
I was told when I bought my 67 GMC 3500 by the Previous Owner that the Previous Previous Owner had installed a different engine in it. I also noticed that the steering wheel is a 1970s one, but the steering column looks 67ish to me.
But the brake light switch that was installed in it has "shaved" sides, right on top of the threads for the retention nut. So I bought a new switch today, and when I went to install it I found that the hole for the switch to mount in is SQUARE, and will not accept the factory-correct round one. What The Hell?!?!?!
Now I know why the old one was shaved. But what type of switch fits a square mount hole? Was there some weird type of square-shaped brake light switch for these back in 1967?
FRANKENTRUCK 1981 Chevrolet C10 Shortbed Stepside
GRANDTRUCK 1968 Chevrolet C10 Stepside Longbed
http://67-72chevytrucks.com/vboard/s...d.php?t=584617
PROJECT JIGSAW 1967 GMC C3500
GREAT WHITE 1986 Blazer M1009
HIGHWAY BY THE SEA is offline   Reply With Quote
Old 12-07-2018, 07:21 PM   #2
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Brake switch mystery...
Not that I have ever herd of. My 67 has the round one like my 71.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 12-07-2018, 07:27 PM   #3
michael bustamante
michael bustamante's Avatar
my 67 is round as well. but mines a chevy not GMC
does you 3500 have a power brake system?
1967custom
michael bustamante is offline   Reply With Quote
Old 12-07-2018, 07:28 PM   #4
ray_mcavoy
It sounds like a previous owner may have mounted the brake light switch in the hole that's normally used for the rubber bumper that the pedal arm hits against at the upper limit of it's travel. If I remember correctly, those rubber bumpers fit into a square / rectangular shaped hole.
ray_mcavoy is offline   Reply With Quote
Old 12-07-2018, 08:20 PM   #5
HIGHWAY BY THE SEA
Mystery solved!!! After I read your post I went outside and checked, and it appears that this is EXACTLY what he did! The shaved switch fits perfectly into that square hole (missing it's rubber stopper). I have never installed a brake light switch into a 67 - 72 GM before, but I thought that the setup looked strange. Good call Ray! And thanks to all who responded!
Old 12-07-2018, 08:31 PM   #6
Steeveedee
Who Changed This?
Steeveedee's Avatar
So what stops the brake pedal lever when it comes back up? That might be why the switch needs to be replaced, if the switch is doing it.
~Steven
Simi Valley, CA
Steeveedee is offline   Reply With Quote
Old 12-07-2018, 08:52 PM   #7
Andy4639
Old member
Andy4639's Avatar
Ha! You got to love people who improvise!
That would explain the square and yes thats why the switch has stopped working taking the hit everytime you let off the pedal.
The switch is up over top of the column and is a hassel to get out and back in. I have a 1x1 about 1ft long I wedge in between the pedal and seat bracket. This holds the brake down until I get the switch out and the new one back in. Then I release it and adjust the switch. Then I set it again to tighten down.
Old 12-07-2018, 11:36 PM   #8
Steeveedee
Who Changed This?
Steeveedee's Avatar
Yes, I've replaced the switch in the past and I'll agree that it is a real "sweetheart" to replace.
~Steven
Simi Valley, CA
