Old 12-11-2018, 09:48 PM   #1
hugger6933
Lightbulb C-30 no crank still, fresh starter, Where is the NSS?
I suspect the way my truck is acting it seems like a Neutral safety switch so where is it. Before you race to tell me it is on the column down by the firewall, my truck is a granny low 4 speed manual trans. Thanks in advance for the help I'm drawing a blank
hugger6933 is offline   Reply With Quote
Old 12-11-2018, 10:00 PM   #2
hugger6933
Re: C-30 no crank still, fresh starter, Where is the NSS?
Ok so no NSS on the 4 speed trucks, is there a clutch switch or something? What keeps the truck from cranking with the clutch not pushed or the truck in gear. Isnt there some kind of power interrupter of some sort dealing with the clutch pedal?
Old 12-11-2018, 10:14 PM   #3
AussieinNC
Moderator
AussieinNC's Avatar
Try looking up on the clutch pedal...but it may have been removed....
Push and hold the clutch pedal down then try to crank...
If still no crank, start from the basics...
Make sure trans is in Neutral...and park brake applied
Run a small clip on lead from the Solenoid terminal on the starter and tap the other end of lead to a positive battery source...starter motor should crank, if not, check ground strap battery to engine and engine to chassis.
Get it to crank this way first...then go to next step.
Remove ignition switch from dash, keeping plug attached to the switch...
Turn ignition on and check for 12V battery terminal on switch...
Turn switch to Start,,,check for 12 v on Sol terminal...
If both are ok...run a temporary lead from Sol terminal on switch to Solenoid on Starter...
Turn ign switch to crank and engine should crank...
If yes...you have a wiring loom issue...
In most cases the NSS fails internally....you can bypass it and leave the temp lead in place..
Let us know how you go..
Family and country before all others...
2006 Chevy Silverado (Daily Driver)
2012 Chevy Equinox
AussieinNC is offline   Reply With Quote
Old 12-12-2018, 08:26 PM   #4
AussieinNC
Moderator
AussieinNC's Avatar
One of the most common areas of failure in the loom is the cabin to engine bay connector plug...drivers side near the hood hinge...
They corrode badly....
Just a suggestion...
2012 Chevy Equinox
Old 12-12-2018, 08:32 PM   #5
oldgold70c10
Who's got steelies?
oldgold70c10's Avatar
These do not have any safety switches. Trace the purple wire from the starter to the ignition switch. It might be in the harness or it might be the ignition switch.
If the purple wire looks discolored at the back of the switch, it is likely the switch or plug.
1969 C10 LWB W/ 250 I6 & 3spd
1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver.
1975 Chevelle Malibu Classic Coupe 350/th350 mint green
1970 C20 Suburban 350/700R4 4.10 gearing green & white
1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver
1983 GMC 1500 Sierra 305/SM465 2.73 rear end
How to add a trip odometer to your 67-72 stock speedometer
How to rebuild your Q-Jet
My Truck Page
My Youtube Channel
oldgold70c10 is offline   Reply With Quote
Old 12-12-2018, 09:41 PM   #6
towbar
towbar's Avatar
Location: Marshall, NC....heart of the Appalachians.....aka, Gods country!!
don't overlook fusible links...chased my tail for a while because of a failed link.
towbar is offline   Reply With Quote
Old 12-13-2018, 09:05 PM   #7
El Dorado Jim
sub'd
El Dorado Jim is offline   Reply With Quote
