Old 12-14-2018, 09:54 PM   #1
Sharptrans
Will a 67 c20 cab work on a C10 chassis
Hi, I’m considering buying a 67 c20 to use on my C10 project. Are the cabs the same? Mounts etc?
Sharptrans is offline   Reply With Quote
Old 12-14-2018, 10:04 PM   #2
notsolo
notsolo's Avatar
Re: Will a 67 c20 cab work on a C10 chassis
I think cabs are very close, C20 maybe high hump...and rear cab mounts might be different also, but can be changed out to fit. Not a deal breaker.
notsolo is offline   Reply With Quote
Old 12-14-2018, 10:09 PM   #3
Sharptrans
Ok, thx. I’d like to use cab and nose on a no limit chassis.
Old 12-14-2018, 10:31 PM   #4
10-30 cabs are all the same. The rear cab mount brackets on a C10 frame are different requiring unique cab mounts. So just use C/10 cab mounts and you'll be good
Old 12-15-2018, 12:30 AM   #5
57larry
yes, good luck on the build
57larry is offline   Reply With Quote
Old 12-15-2018, 10:20 AM   #6
CharlieBrown
CharlieBrown's Avatar
cab don't care
1972 Cheyenne Super..owned since 1978
1972 Surburban 4x4
1972 Cheyenne 4x4 3/4 ton.....sold
1972 Cheyenne 2wd...named Death Row
CharlieBrown is offline   Reply With Quote
