01-01-2019, 01:14 AM | #1 |
Plans for your trucks this year?
Me, I'm going to replace my new correct oil pan bolts, because the bolts for the timing chain cover are too short with a on-piece gasket, same with the rears. Another lesson learned. I suppose I could install a cork gasket, but nah, I'll use ARP bolts. A little irritating, I like correct bolts But a matching set will have to work. At least they're black and a better bolt, the others are clear.
Other than that I hope to have my chassis done by spring. Then I face the reality paint prison may be too long, which means plan B. Plan B has a reputation, and he charges for it too. It's another 7K to get him motivated, and I haven't even asked. Thing is he'll get it done. He's even my nephew......... He did these for me recently, $200, which was a deal. But I know better. 16K minimum. The bed is already done less paint, and the rest is a nice start. I'll get a dry run and the moldings installed for it. Then I'm looking at 2020 to finish. Takes me so long
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
01-01-2019, 02:28 AM | #2 |
Re: Plans for your trucks this year?
Its a little early, but ill try. I plan on having it drivable by may. I've about finished the wiring and I hate wring. Gonna need wheels and tires, but working on a seat first. Burnouts by May, that's the goal.
2003 Dodge 2500 1969 C10 2014 Camaro SS/RS/1LE |
01-01-2019, 02:59 AM | #3 |
At the body shop.
Fix the rusted cab supports and rockers.
" That didnt make it any newer " " Dont antique the equipment " |
01-01-2019, 04:53 AM | #4 |
Lowering my 1970 SWB step by 4/6 and adding disc brakes, hopefully. I have a lot of things on my list, but that would make it more enjoyable to drive at least.
DAVE Edmonton, Alberta 1959 Apache 1967 K20 1968 C20 1970 C10 1972 GMC 2500 1981 C10 |
01-01-2019, 05:51 AM | #5 |
Get it back together and drive it!! I hate cabin fever
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
01-01-2019, 07:22 AM | #6 |
laying low
^^^^^ that!
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
01-01-2019, 11:28 AM | #7 |
A whole lot more than last year. I'm not even going to say what I hope to get done. Kind like a new years resolution. Don't want to set myself up for failure. I could make a list of what the '72 needs and see what's checked off a year from today. The big things needed are repair rockers/one corner/new body mounts/window seals & anti-rattle on the body and seals in engine/trans/t-case. Tunes would also be nice.
01-01-2019, 11:56 AM | #8 |
laying low
You got any plans for the 67 stepper Tim?
The cab and engine/trans are back on the frame right?
01-01-2019, 12:38 PM | #9 |
My freshly rebuilt 700r4 transmission is installed and tomorrow I take the driveshaft in to be shortened and re-balanced. It will be back on the road next week but as this is my first 700r4, I have a lot to learn about getting it setup. I went with a local shop to build it and a mechanic I have know for years is doing the install and both are very experienced with this swap. I sure hope it helps my gas mileage!
01-01-2019, 12:48 PM | #10 |
BlahBlahBlah
OMG, already putting the pressure on! Ok I did make a few trades yesterday on some parts and some whole trucks. And made arrangements for storage and shipping. So If I can keep this up ... OK, I wont be able to do that. No biggie though, I think I have the most fun just moving stuff around =)
01-01-2019, 12:57 PM | #11 |
When I changed the oil in the fall I found coolant but I haven’t had the time to mess with it. So I need to hunt down the problem.
1972 Chevy Cheyenne Super - 454 BBC 1995 GMC C1500 SLE - 350 SBC 1984 Cutlass Supreme Brougham - 1979 350 SBC |
01-01-2019, 01:03 PM | #12 |
Simple - Drive it
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
01-01-2019, 01:06 PM | #13 |
I would agree 70cst! I plan on keeping mine, driving it and getting more and more things addressed this year.
Blessed be the one by John! This is definitely a gooder day! |
01-01-2019, 01:10 PM | #14 |
Get it running and driving before Christmas.
72 C10 lwb fleetside aka Big Rhonda. Still plugging away. Build thread: http://67-72chevytrucks.com/vboard/s...42#post8247142 |
01-01-2019, 02:30 PM | #15 |
Fix the rockers, corners, and cab supports.
Rust repair on the door bottoms. Mock up the engine and transmission and make a crossmember for the TKO500. Get the parts and build the Vortec headed 383. Mount the rear tank and mod/fit the bed floor accordingly. Paint the frame so maybe I can attempt to assemble this pile of parts. Man, I better get my butt to work
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
01-01-2019, 02:32 PM | #16 |
Swap from carb to EFI, rebuild trans with new close ratio planetary, get faster at autocross!
01-01-2019, 04:41 PM | #17 |
Finish the disc brake conversion. Get front end back together. Get engine running and drive it. Missed last summer by dragging feet and don’t want to miss a second. Will be installing 4speed but will need to build a console at that time so if the three speed makes it through another summer behind the v8 then 4speed is next winter project. If it breaks that will move up on the list.
Not sure how to turn pic, that makes Me dizzy. Sorry guys. |
01-01-2019, 04:47 PM | #18 |
Rebuild the transfer case, find a proper bench seat, and hopefully find some driver quality doors and a better box.
All fairly simple(hopefully) stuff really, but I want to get my 61 done before I go too crazy with this one. Two trucks torn apart = nothing gets done ever.
Nick 1961 Apache short stepside 4X4 SBW 348/4 speed 1960 Apache C-20 long fleet custom cab BBW 283/4 Speed 1967 rust bucket Olds Cutlass with a 455 1972 GMC K-15 350/4 speed long fleet |
01-01-2019, 04:58 PM | #19 |
laying low
turn
01-01-2019, 05:14 PM | #20 |
Thanks Boog, I have been deep in the K20 pic thread and forgot I was on the 67 side. Mine is a 63 so sorry for the invasion.
01-01-2019, 05:23 PM | #21 |
had the 402rbuilt last year and the rear seal leaks......put a wood bed in and was given a wrong board (driver side with holes) and they still haven't sent me proper one (since July-classic -industries) gonna put in a new wire harness and fix the mistakes.
01-01-2019, 06:00 PM | #22 |
To finally get to see it in July and drive it. Then just start the long process of fixing it up.
71 C10 |
01-01-2019, 06:14 PM | #23 |
What do you mean finally get to see it?
01-01-2019, 06:25 PM | #24 |
Dewayne what bed cover do you have on your truck?
Doug 71 Sierra Grande C25 16 Sierra 2500HD All Terrain 23 Chevy Tahoe Z71 https://paypal.me/digdug7131?locale.x=en_US |
01-01-2019, 06:48 PM | #25 |
Plans for 2019:
1. Drive truck way more often (only managed approx. 400 miles last year) 2. Repair leaking rear main seal 3. Replace HEI distributor with a small body HEI 4. Lower the truck down to stock height (ok, maybe stock plus 1"zero rate)
1972 Blazer Highlander 1971 GMC K1500 SWB (sold) 2004 Corvette Z06 CE |
