Old 01-01-2019, 04:06 PM   #1
eighteenninetytwo
interior Sidewall panels - advice needed.
Just about to cover and fit the interior bed sidewall panels. I used the old ones as a template and used plyboard. Does anyone have any tips as to how I can use the old screw holes in the supporting struts to screw them into place when they are carpeted? round the edges I can see and mark to drill them but I cant do that with the supports in the middle of the walls.
eighteenninetytwo is offline   Reply With Quote
Old 01-03-2019, 02:44 PM   #2
eighteenninetytwo
Re: interior Sidewall panels - advice needed.
Someone must have done this??
Further question - as this is a functional driver with dogs kids bikes etc involved. is carpet even the best covering for the sidewalls? or should I just paint the wood black and be done with it? What have others done - pics would be useful.
Old 01-04-2019, 08:13 AM   #3
Mcmarkrazz
Just get new self tapping SS screws and make new holes that’s what I just did
Mcmarkrazz is offline   Reply With Quote
Old 01-06-2019, 12:41 AM   #4
mickeykreg
mickeykreg's Avatar
Most of the way through post 55 is what I did. Not sure if it works for what your up to, but an idea maybe.
http://http://67-72chevytrucks.com/v...=740291&page=3
'80 SRW C35 - 355/700R4/4:11/2.5-3/DD
'77 Cheyenne K5 - Roller cam 355/NV4500/205/4:88's/35's/DD
rust repair on the '77
http://67-72chevytrucks.com/vboard/s...d.php?t=740291
mickeykreg is offline   Reply With Quote
Old 01-06-2019, 01:01 AM   #5
Killer Bee
Killer Bee's Avatar
sounds like your trying to locate screws into blind holes in the field behind your new panel..
what I've done is start some headless screws in the mounting locations, line up the panel or whatever part goes there, and tap it on the screws to leave witness marks.. drill your through holes there and you should be able to hit the screw hole with a little finagling.. you can even enlarge the holes slightly to increase finagling room as long as you maintain enough grip under the screw head..
I have also made paper or cardboard templates of my hole mounting locations and transferred that to my part.. just have to be careful with orientation.. holes in the old panel may help in this manner..
good luck!
btw, link above didn't work for me but I found the thread.. that post 55 is a doozy
rust repair on the '77...here goes nothin
Old 02-07-2020, 02:58 PM   #6
KevsClassics
TILT COLUMN GURU
KevsClassics's Avatar
Instagram
kevs_classics64
64 Impala SS Conv
72 Blazer 2wd
75 Jimmy 2wd
63 Belair wagon
02 Silverado ext cab. DD
RIP EL JAY
KevsClassics is offline   Reply With Quote
