Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > Heavy Haulers
Old 01-02-2019, 07:10 AM   #1
prop7010
11r22.5 on a c60
Hello,
Currently in the process of swapping out the stock 20 inch dayton split rims on a 1970 c60 for something a bit more common. I've read a few peoples posts about using 10r22.5's but not 11's. Anyone try it and run into fitment issues? Reason for going a bit wider being the availability of cheap 11r22.5 rubber.
prop7010 is offline   Reply With Quote
Old 01-03-2019, 10:21 PM   #2
Airdirect
Re: 11r22.5 on a c60
I put 11R22.5 on my 1979 C70. They fit just fine.
http://67-72chevytrucks.com/vboard/s...=721374&page=5
Airdirect is offline   Reply With Quote
Old 01-04-2019, 06:04 PM   #3
68Gold/white
Should not be an issue at all. I work on school buses. Most buses went to 11R22.5 tires around 2000. The 11R's are insralled on 8.25 wide rims, the 10R's on 7.5 wide rims, Have seen many 11 R's on 7.5 rims, no problem.
68Gold/white is offline   Reply With Quote
