Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1960 - 1966 Chevrolet & GMC Pickups Message Board > 60-66 Suburbans
Old 01-14-2019, 05:07 PM   #1
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
Clam shell
Does anyone know how to adjust the top clam door. Mine is stiff to close.
Sick5 is offline   Reply With Quote
Old 03-21-2019, 06:20 PM   #2
nadodave
Re: Clam shell
If you find out, PLMK. Mine is very stiff to open. I don't think it is opening all the way either.
nadodave is offline   Reply With Quote
Old 04-18-2019, 12:08 AM   #3
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
Re: Clam shell
Found out you can use 1955-1957 nomads rear brackets to.hold the upper clam door open
Old 04-18-2019, 04:08 PM   #4
Llay R. Rac
Llay R. Rac's Avatar
Re: Clam shell
That is good to know.
I thought that might be possible.
Before i found replacements for my non-catching upper slides I bought a Danchuk Mfg. repair kit for nomad slides. I didnt get around to trying the kit, but i think it would work to fix intact non working slides.
1965 Suburban, 2 wd.,292, 4-speed.
proudly owned and operated since Valentines day 1969.
Llay R. Rac is offline   Reply With Quote
Old 04-18-2019, 04:15 PM   #5
Llay R. Rac
Re: Clam shell
if the pivot pin in the hinge is bent or worn the door will be hard to open.
one of mine is bent slightly (from backing into a pole with the end gate up), lubing it helps. also be sure the slides are lubed.
I recently had my rear window out, i was surprised how light and easy to open the upper gate was without glass in it. if i every need to replace it i will get some light weight lexan or plexiglass.
the 1963 shop manual has instructions to adjust the hinge to center and flush the door to the body. I think your door would have to be way out of adjustment to make it stiff to close. maybe you have too thick weatherstripping or its placed wrong?
Old 04-19-2019, 11:39 AM   #6
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
Re: Clam shell
one issue would be the bottom bracket needs to slitly modified. I purchased a set on ebay for 89. hoping to have them by monday
Old 04-19-2019, 11:41 AM   #7
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
Re: Clam shell
no weather-stripping on the clam doors.. but ill try the pin idea tonight.
Old 04-19-2019, 12:12 PM   #8
perro13
perro13's Avatar
Re: Clam shell
Nomad arms are shorter
perro13 is offline   Reply With Quote
Old 04-19-2019, 04:41 PM   #9
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
Re: Clam shell
Randy
two style of nomads had them.. one is short the other long. I bought the wagon one. just came in. ill take a look at it when I get home
Old 04-19-2019, 04:42 PM   #10
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
Re: Clam shell
what is the length they need to be?
Old 04-19-2019, 06:19 PM   #11
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
Re: Clam shell
Here it is
Old 04-20-2019, 05:22 PM   #12
nadodave
Re: Clam shell
I am converting my hatch to struts. Does anybody know what the thread size is for the embedded nuts in the side of the hatch? I tried 1/4-28 which doesn’t seem to work.
Old 04-20-2019, 09:46 PM   #13
66 Burban
66 Burban's Avatar
Re: Clam shell
Here it is
Yep - 55-57 Nomad supports are definitely too short. They only came in one length - not a long or short.
Remember: "When seconds count, the Police are only minutes away".
Thx,
Billy B.
66 Burban is offline   Reply With Quote
Old 04-22-2019, 04:33 PM   #14
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
Re: Clam shell
you might be right. but in my case it better than nothing. I might need to change the mounting holes to make it work. or extension on it. ive seen on facebook someone selling brackets to use gas assist on them.
Old 04-22-2019, 04:50 PM   #15
nadodave
Re: Clam shell
Hi:
There is a great post in the 60-66 Suburban forum on a gas assist installation. I basically copied the brackets shown in the post, and bought a couple of struts. The only wrinkle for me was that the struts were too short to open the hatch all the way, so I ordered longer ones. Pretty easy mod.
Will see if I can find the post again to share.
Dave
Old 04-22-2019, 04:54 PM   #16
nadodave
Re: Clam shell
Here is the link to the gas strut installation:
http://67-72chevytrucks.com/vboard/s...=504141&page=6
Old 04-22-2019, 05:24 PM   #17
Llay R. Rac
Re: Clam shell
another alternative if you don't want to do gas shocks is camper shell end gate support slides.
before 2001 when i got my first computer I thought endgate slides were made of unobtainium I used a 2x4 or a pole to hold my endgate open.
One day I was in the wallyworld RV section and found a set of slides in a discount bin for $1.99, the end brackets had to be replaced with those from my original slides and the slide was about one inch shorter then the originals, but they worked well for 2 years until i went over a speed bump too fast with the end gate up and one slide "folded". I went back to walmart and they had a set on the regular shelf for $19.99. i bought those and they have been used on my truck for almost 20 years now.
to eliminate the end gate from crashing down and folding again i drilled a hole in the slide and secure it with a nut and bolt when i want to leave the end gate up while driving.
Old 04-23-2019, 12:53 AM   #18
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
Re: Clam shell
Old 04-23-2019, 12:58 AM   #19
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
Re: Clam shell
