Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > Heavy Haulers
Old 01-23-2019, 12:04 PM   #1
oldrider
GMC 6500 Power Steering
Hi,
I'm looking for a power steering pump for a 1975 GMC6500 with a 366 big block. Does anyone know where I can get one, or a part number?
Thanks.
oldrider is offline   Reply With Quote
Old 01-23-2019, 12:27 PM   #2
sweetk30
sweetk30's Avatar
Re: GMC 6500 Power Steering
might be just what you need . i found it under chevy c50-c60 stuff on rockauto in the 1975 year with 366 gas .
https://www.rockauto.com/en/moreinfo...442654&jsn=546
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 01-23-2019, 01:02 PM   #3
oldrider
Hi, Thanks for the prompt reply. I don't know how I missed Rock Auto, I checked pretty much every other site. Just eyeballing it, that looks like my pump, but I think I may try phoning Cardone directly to see if they confirm it.
Thanks again.
Old 01-23-2019, 03:22 PM   #4
sweetk30
sweetk30's Avatar
lots of times i use rock auto to help pin point parts fitment .
weird thing is go to gmc and no listings . yet there basicly the same as chevy . . . . go figure .
Old 01-25-2019, 12:56 PM   #5
oldrider
Hi SweetK30,
I went directly to the Cardone web site, they don't even list this part number anymore, and when I went back to Rock Auto to order one and take my chances, I found out they don't carry them, but would rebuild mine.
So I would need to pay for shipping, and being in Canada duty, both ways, which would make it quite expensive. The only issue with my pump is a leaking shaft seal, so I'm going to try and find one locally.
Thanks for the help.
Old 01-25-2019, 04:26 PM   #6
sweetk30
sweetk30's Avatar
no problem .
if just a seal then should be easy fix to find local .
Old 01-25-2019, 09:00 PM   #7
renegade6
The power steering pump inner part should be the same across many years of GM trucks. May just have to swap out the outer body.
Brandon
63 Biscayne https://www.pro-touring.com/threads/90718-63-Biscayne
57 Chevy Truck (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=321380
72 K20 Long bed stepside (wife's)
72 K20 Long bed 396 (flip or keep...?)
The latest build: http://67-72chevytrucks.com/vboard/s...76#post8438476
renegade6 is offline   Reply With Quote
Old 01-25-2019, 11:13 PM   #8
Robert1970C20rstbukt
Robert1970C20rstbukt's Avatar
Looked at the Gates catalog, the shaft seal part number is 348740. The whole kit with the seal and new O rings is 350310.
RJD
1984 Chevrolet C30 welding truck 454/SM465
1977 GMC C15 pickup 350/TH350
1970 Chevrolet C20 pickup 350/TH400
1970 Chevrolet K20 Suburban 454/TH350
1969 GMC 8500 478M V6/5 spd winch truck
Robert1970C20rstbukt is offline   Reply With Quote
Old 01-27-2019, 12:06 AM   #9
rkn463
rkn463's Avatar
Like sweetk30 said, if it just needs sealing, then it is actually quite easy. If you check out post number 85 in my build thread you can see where I had mine blown apart while cleaning it up and putting in the seal kit. My kit came from AutoZone, they seem to have a lot more parts for medium duty trucks than a lot of other parts stores.
-Richard
I may have too many Chevys... Is that possible?
68 c50 pickup build: http://67-72chevytrucks.com/vboard/s...d.php?t=704713
rkn463 is offline   Reply With Quote
