Old 01-24-2019, 05:31 PM   #1
1971Stepside
Almost Satisfied
1971Stepside's Avatar
Wiring Ignition
Gentleman. I am very close to turning the key for the first time on my LS. My goal is to fire her on my 50th birthday next month. I found my original ignition and key in a box and would like to use it to start the motor. Keep in mind I have the cab sitting on the frame, but basically we have a rolling chassis without any wiring in the cab. How would I go about wiring up the ignition to work? I know i need to go to the starter, but what else and if you have a diagram of the pins I would really appreciate it.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 01-24-2019, 05:56 PM   #2
mongocanfly
Post Whore
mongocanfly's Avatar
Re: Wiring Ignition
All you'll need from the switch to the LS ecm is switch on power...other than that the switch works just like it would on any engine...
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 01-24-2019, 06:37 PM   #3
1971Stepside
Almost Satisfied
Re: Wiring Ignition
Well that sounds simple enough, but I took this thing apart so long ago that I don't remember what wire went to where on the ignition. I can a lot of mechanical work, but wiring just throws me.
Old 01-24-2019, 06:55 PM   #4
1971Stepside
Almost Satisfied
Re: Wiring Ignition
I guess to clarify:
Purple wire = Starter Terminal
Red Wire = To Battery
Brown Wire = Acc Wire (do I need to hook this to anything now?)
Brown/White Wire = Alternator Reg (I assume I don't need)
Pink Wire = Ignition Coil (can I use this one for the ECM?)
Tan Wire = Brake Warning to Dash (don't need now)
Green Wire = Temp Sender to Dash (don't need now)
Dashed Purple Wire = Neutral Start Switch (don't need now)
Is this correct? Thank you in advance.
Old 01-24-2019, 08:02 PM   #5
mongocanfly
Post Whore
Re: Wiring Ignition
the wire that went to the coil/hei is the one I used for my switch on power....I think it is pink
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 01-25-2019, 10:00 AM   #6
cebra
Re: Wiring Ignition
This is how mine is wired anyways:
Purple wire = Starter Terminal (Needed to Start)
Red Wire = To Battery (Needed to Feed Power to Switch)
Pink Wire = Ignition Coil (Yes, Goes to Pink/Black on my Harness to Power ECU)
Brown Wire = Acc Wire (Not Needed Now)
Brown/White Wire = Alternator Reg (Not Needed Now)
My Daily Driver Build: http://67-72chevytrucks.com/vboard/s...d.php?t=755668
cebra is offline   Reply With Quote
Old 01-25-2019, 10:16 AM   #7
1971Stepside
Almost Satisfied
Re: Wiring Ignition
Thank you cebra and mongocanfly. Looking forward to this.
Old 01-25-2019, 01:23 PM   #8
1971Stepside
Almost Satisfied
Re: Wiring Ignition
Just confirming...does this look correct?
Old 09-20-2019, 02:52 PM   #9
TA_C10
TA_C10's Avatar
Re: Wiring Ignition
Stepside I just ran across this thread again. I am starting to plan out my power protection plan and bulkhead/PCM harness wiring. Did you wire your alt to the starter? What did you do if I may ask? I'm trying to figure out what size circuit breakers to use and where.
This is something similar to what I am thinking.
TA_C10 Stage 1 build - http://67-72chevytrucks.com/vboard/s....php?p=8333444
"It's only money".
TA_C10 is offline   Reply With Quote
