Old 02-06-2019, 04:47 AM   #1
71GreenJunk
Options for More Pos. Caster?
I seem to recall reading that '73+ a-arms have additional caster built in compared to my '71. Is this true, if so, how much? My understanding is that I should look for about 8* positive caster. Most aftermarket arms don't seem to get you very close to 8* or they use coil overs which seems a bit much for something that's just a daily driver. I look at shocks being a consumable part like a battery or tires and coil over is a lot more expensive than a set of normal gas shocks. Think my last ones were $45 for a pair. Is this an unreasonable way of thinking for not going to coilovers?
71GreenJunk is offline   Reply With Quote
Old 02-06-2019, 07:31 AM   #2
PGSigns
PGSigns's Avatar
Re: Options for More Pos. Caster?
Do a search for caster mod in this forum section. I did it with my 66 using 73 and up arms. I redrilled the locator hole a half inch back and easily got what I was looking for and that was 5 degrees. Unless you are running a drag car I think 8 is to much for a driver. Mine runs down the road really well with the 5 degrees caster. 0 camber and a 1/8" of toe. I am running Beltech street performance shocks and really like them. The truck is lowered 4 1/2 front and 6 rear with a super track bar.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 02-06-2019, 07:32 AM   #3
PGSigns
PGSigns's Avatar
Here id the thread.
http://67-72chevytrucks.com/vboard/s...ght=caster+mod
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 02-06-2019, 09:25 AM   #4
71GreenJunk
Dang. I got my terms mixed up. I've had the truck somewhere around 120-130 mph and it felt fine so I'm not too worried about the caster after all. It was the camber I was wanting more of. -1.5* seems pretty good if that's even possible? About what I see on performance late models.
Yeah 5* caster should be plenty after all. I had looked at that caster mod before.
Old 02-06-2019, 11:28 AM   #5
SCOTI
SCOTI's Avatar
- 1.5 camber is going to wear tires way faster than you would expect. Factory trucks call for +.5 camber w/o aggressive wear. I start @ -.5 for a daily driven vehicle & try to get close to that. If it's just a toy, more aggressive Neg camber can be dialed in.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-06-2019, 05:14 PM   #6
71GreenJunk
Makes sense. There's no free lunch. -0.5* is still better than a lot of car's stock alignment settings.
Old 02-06-2019, 07:48 PM   #7
SCOTI
SCOTI's Avatar
Yes. And, since OE calls for +.5 camber w/o wear issues, going NEG is not going to yield 'more' wear vs. POS yet the tire contact patch (& effectively handling) will improve.
For reference, my dually is modified & was about 7° caster & -.6 camber (I would have to look @ my sheet to be 100% correct on the actual numbers).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
