Old 11-24-2003, 01:57 AM   #1
72addict
Need k20 front backing plates
Looking for a pair of front backing plates for a k20 4x4. I want the solid ones. Thanks
1957 Cameo
72addict is offline   Reply With Quote
Old 11-24-2003, 07:20 PM   #2
jmanz69
Careful, they attack...
jmanz69's Avatar
I used a pair of those to make the backing plates for my rear discs. They shouldn't be too hard to come by.
jmanz69 is offline   Reply With Quote
Old 11-25-2003, 06:56 AM   #3
72addict
Golly, where did you get that idea?
1957 Cameo
Old 11-25-2003, 08:44 AM   #4
jmanz69
jmanz69's Avatar
hehe, uhh I don't know
Old 11-25-2003, 06:04 PM   #5
72addict
Did you get your conversion all done?
1957 Cameo
Old 11-25-2003, 06:34 PM   #6
jmanz69
jmanz69's Avatar
Still can't find the right rotors. I had a set of Jeep Cherokee like you said, but they had 5 on 4 3/4 lugs. So I am still looking for a set with 5 on 5, maybe old caddy? Any ideas?
Are you going to do another conversion too?
Old 11-26-2003, 07:01 AM   #7
72addict
Putting discs on the 1970 Blue and white GMC. I really do not know what the rotors on the bronze and white GMC came off of. The parts jockey at Autozone told me Jeep, but I am not sure if he graduated the 9th grade. Go to a parts store and ask to look at their rotor book that shows them by size and lug pattern. I am sure I do not have any info on them, but I will check. Good luck
1957 Cameo
Old 11-28-2003, 07:44 PM   #8
jmanz69
jmanz69's Avatar
back to the top, someone has to have these!
Old 11-28-2003, 10:45 PM   #9
Rod
78-80 cadillac seville disc should work for you.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 11-28-2003, 10:48 PM   #10
jmanz69
jmanz69's Avatar
front or rear? I was kinda thinking along that line also, hadn't had a chance to check into it yet though. Thanks for the info.
Old 11-28-2003, 10:52 PM   #11
jmanz69
jmanz69's Avatar
here is a pic of my progress so far. 72 addict gave me the idea, and I happened to have a spare set of backing plates sitting around.
Old 11-28-2003, 11:37 PM   #12
Rod
rear ... perhaps the fronts are the same. But rear ones will work.
Old 11-29-2003, 12:58 AM   #13
72addict
Hey jmanz69 I did not notice it when you sent me the pics the first time but, the bleeder on the caliper is supposed to point up. This makes it so the bleeder is higher than the piston in the caliper and all the air will not "pocket" in the piston. Also I used rubber hose at each caliper so changing pads would not be a problem.
1957 Cameo
Old 11-29-2003, 09:41 AM   #14
jmanz69
jmanz69's Avatar
I think I had the wrong caliper on the side I was fitting, but I was just trying to see what it would look like. I will be sure I put them on the correcr side when I finally put them together. I palnned on rubber hose, especially since the caliper has to be able to move as the pads wear. I haven't done any plumbingnyet, still on the mechanical part. Thanks for noticing though. I might not have til after I put it all together.
