![]() Join Date: Aug 2013
WTB correct rag joint
If some one could please help me find the correct rag joint for a 66 K10 manual gearbox. Mine doesn’t have a flat spot in the splined section, if more dimensions are need for this item please respond, thank you.
![]() Join Date: Mar 2012
Re: WTB correct rag joint
I will round one up and send it. Thanks Lyle
Check The Champ, Demonstrator
![]() Join Date: Jun 2009
That's interesting , parts book lists two different part numbers for 63-66.5689757 coupling and lower flange. 5682485 Intermediate shaft flange same as for 60-62 but EXC 4WD. Does the one you have got any casting numbers on it?
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
Quick internet search Chevrolet passenger car has the same 5689757 part number as well as Buick's.
i will check for the casting numbers. my 65 2wheel drive has one with a flat spot on it, but its a newer steering box 67 i think. while my 66 burb 4x4 doesnt have a flat spot its all splines, and the 65's is too small diameter to fit on the 4x4.
From my reading there's a 3/4" shaft and a 13/16" shaft versions.
![]() ![]() Join Date: Apr 2012
I have a 5689757 rag joint NOS . C10 is same as K10
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK |
Not sure if it helps, but...
https://www.google.com/search?q=66+K...w=1171&bih=653 |
#12 | |
#13 |
#14 |
#15 |
i’ll take it. Pm sent
