02-25-2019, 10:16 PM | #1 |
T221 lube opinions
Just finishing up a rebuild of my T221 and wondering if anybody out there has opinions on what lube is best to keep it happy. I keep a bucket of both GL 4/5 and Synthetic gear lubes for my old junk, and would tend to use one or the other unless somebody has a better suggestion.
For the record I always use a mag plug and change the lube every two years in all the trans/x-fers and diffs I own. Thanks for any input Tom
65 short stepside K10 292-SM420-T221 8 lug closed D44 front NoSpin HO72 4.10 rear |
02-25-2019, 10:19 PM | #2 |
Re: T221 lube opinions
my old gear to gear stuff i do 1/2 qt of lucus oil stabilizer and top off with dino grade oil .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
02-27-2019, 07:26 PM | #3 | |
Guy who rebuilt mine recommended not using synthetic, so wondering what others have had good luck with. Never used oil stabilizer, I'll have to read up on it
02-27-2019, 07:57 PM | #4 | |
IIRC I ran 85w - 140 wt Valvoline when I had mine. Ive been synthetic for the past couple of years with the 205 though. Its a mix of Amsoil MTL and Redline Shockproof Light.
Chris '63 k15 long step Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205 52" front and 63" rear spring swap D44 / 14bff - disc axles Milemarker 9K and 10.5K hydraulic winches 63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29 |
02-28-2019, 08:33 PM | #5 |
I would just put the same oil you're putting in the 420. Keep it the same and you can just get the GL/4. I've been getting the Sta-Lube off Amazon.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 j
White K20 |
03-10-2019, 02:15 PM | #6 |
What?
I stick with plain 90w gear oil.
Chris 1968 K20 Suburban 1972 K10 LWB PU |
03-11-2019, 10:33 PM | #7 |
Appreciate you all sharing opinions,
Thanks, Tom
03-12-2019, 04:49 AM | #8 |
A straight 90 should work fine.
