03-06-2019, 07:51 PM | #1 |
Transmission Lines
Just wondering if anybody has used the Russell Twist Lok hose/fittings for transmission cooler lines?
Chuck Instagram: c_lo_garage Check out my 1966 C10 project "El Viejito" here: http://67-72chevytrucks.com/vboard/s...d.php?t=674614 |
03-06-2019, 11:37 PM | #2 |
BMW & ASE Master Certified
Re: Transmission Lines
I'm running the aeroquip push lock stuff and summit ends between hard line and cooler lines. Also using same combo for the low pressure fuel system
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress |
03-07-2019, 02:35 AM | #3 |
I ran Russell power flex. Pretty cool stuff.
1956 Chevy Bel Air 2 door 1956 Chevy 210 4 Door 1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD 1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E 1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD* GO GO!!! |
03-07-2019, 01:55 PM | #4 |
Subscribing and tacking on to this thread - Seems like the Russell Powerflex is the way to go - what ends were used to connect to the radiator/factory cooler and the trans end?
Going to be running a 4L80E but should be the same connectors as the 4L60E I believe. EDIT: Did some digging and found this: Converts the 4L80E stock fittings to -6an fitting - which if I understand correctly means I'll be able to just run standard high pressure braided line suitable for trans fluid to the compression fittings at the radiator/stock cooler end. Radiator/stock cooler is from a 2006 Yukon that was originally equipped with a 4L60E http://www.purechoicemotorsports.com...rod/prd338.htm Last edited by skyphix; 03-07-2019 at 02:04 PM. |
03-07-2019, 02:36 PM | #5 |
I removed the stock fitting on my transmission and install a fitting that went from the transmission case to a -6an fitting.
https://rover.ebay.com/rover/0/0/0?m...2F132719580276
03-07-2019, 03:16 PM | #6 |
I recently purchased the Russell adapters from transmission fitting to -6an and also purchased adapters to -6an from my radiator.
I already have the twist-lok lines and fittings for my fuel system, I just wasn't sure if it was able to be used for transmission cooling as well. When assembling my fuel system, I had no problem putting the line on the fittings, they are double barbed and you have to push like crazy to install. I have no worries about these coming lose, plus it was real quick to put together.
03-07-2019, 06:21 PM | #7 | |
