Old 03-08-2019, 11:37 PM   #1
Fast Chevy
1955 Chevy SS
Started this project months ago, but just got around to posting. 1955 Chevy on a 2006 Chevy Trailblazer SS chassis.
Fast Chevy is offline   Reply With Quote
Old 03-08-2019, 11:44 PM   #2
Fast Chevy
Re: 1955 Chevy SS
More photos, dash actually fit pretty good!
Jeff
Old 03-09-2019, 12:39 AM   #3
NorCalGal
NorCalGal's Avatar
Re: 1955 Chevy SS
That worked out well, and that dash looks great
Jan's 53
NorCalGal is offline   Reply With Quote
Old 03-09-2019, 12:50 AM   #4
Fast Chevy
Re: 1955 Chevy SS
Thanks, actually using firewall and floor pan worked out good for lining everything up. I did have to remove about 11/2 “ off each end of dash though. Added a few more pics. Moved bumper back about 2” , didn’t like how it stuckout. Console went in good, used back part for interior fuse box.
Jeff
Old 03-09-2019, 02:10 PM   #5
NorCalGal
NorCalGal's Avatar
Re: 1955 Chevy SS
Looking forward to updates
Jan's 53
Old 03-13-2019, 11:28 AM   #6
mikebte
Re: 1955 Chevy SS
I think you have the right idea, this is a cool swap and will make for on every nice 55'
mikebte is offline   Reply With Quote
Old 03-20-2019, 04:06 AM   #7
Nut Case
Nut Case's Avatar
Re: 1955 Chevy SS
Fast
Boy do you live up to your name.....
Strong work, very creative
Keep on keepin on
Nuttz
Been there, wrecked that
Nut Case is offline   Reply With Quote
Old 03-20-2019, 08:01 AM   #8
Fast Chevy
Re: 1955 Chevy SS
Thanks, has gone fast but being retired helps!
Jeff
Old 03-20-2019, 08:50 PM   #9
Fast Chevy
Re: 1955 Chevy SS
Stance with new wheels n tires.
Old 03-26-2019, 12:22 PM   #10
dsraven
Re: 1955 Chevy SS
what size of tires did you end up with?
looks good.
Old 03-26-2019, 03:26 PM   #11
Fast Chevy
Re: 1955 Chevy SS
I went with 245/45/17s, was going to go with 18” but it would have been really close on front wheelwell.
Jeff
Old 03-26-2019, 03:28 PM   #12
NorCalGal
NorCalGal's Avatar
Re: 1955 Chevy SS
You certainly made that look easy. More pictures please!
Jan's 53
Old 03-26-2019, 03:43 PM   #13
dsraven
Re: 1955 Chevy SS
just curious what ratio you have out back, what your highway cruising speed is with the 25" tall tires. I am thinking of going with a 28" tall tire, like a 235/60r17. not sure how that will fit into the wheel opening as far as turning and rubbing on bumps but also, with the 3.73 ratio I have, the cruising rpm will be lower so less drone and still should have pretty good pick up and mileage. how do you find yours? do you have a pic from the side showing the tires in the openings?
Old 03-26-2019, 03:43 PM   #14
Fast Chevy
Re: 1955 Chevy SS
Weather starting to get nicer here so been working in the back clearing the woods, got a nice fire going n later it’ll be roasted hot dogs n smores lol. It was pretty easy using 5he front firewall n front of the floorpan off of the SS. In keeping the floor pan I used the existing SS body mount location that way everything lined up in the cab.
Jeff
Old 03-26-2019, 03:59 PM   #15
Fast Chevy
Re: 1955 Chevy SS
Ratio out back is factory which I believe is a 4.10. Haven’t driven it yet so don’t know about what effect changing tire size will have. I need to finish bed n interior but it will slow down now that weather is getting nicer. I can take a better photo of front n give u some measurements if u like, rear won’t matter cause bed not set where I’m going to leave it.
Jeff
Old 03-26-2019, 04:06 PM   #16
dsraven
Re: 1955 Chevy SS
check your pm's when you get a minute. s'mores come first, lol.
Old 03-27-2019, 10:06 AM   #17
dsraven
Re: 1955 Chevy SS
are you using the original bed with the wood floor or changing it up to something else, composite, steel floor? have you got the bed mounted yet? gonna use the trailblazer spare tire under the bed or run without a spare maybe?
Old 03-27-2019, 05:36 PM   #18
Fast Chevy
Re: 1955 Chevy SS
Probably going with an oak bed since I have the oak( make furniture too). Don’t have bed in final location yet but close, probably put spare tire back on but it depends what I come up for the rear end, thinking about bending some metal in a quarter circle underneath tailgate n then mounting my taillights in it. Still up in the air on it.
Jeff
Old 03-27-2019, 09:57 PM   #19
dsraven
Re: 1955 Chevy SS
I found on mine that the 235/60r17's wouldn't quite fit under the box with the original spare tire carrier because the truck sits pretty low. I pinned the suspension at ride height with the original envoy body on top then stripped it off and put the old truck cab on top of the frame with the rockers about even with the bottom of the frame. that way there is prolly no surprises if it were to bottom out on speed bumps etc. the floor in the truck is about 2-2.5" lower than it used to be. is that roughly what yours works out to? I have the spare tire style rear fenders so will likely just use that method. it would be interesting to see the tail light system you have planned. I see you recessed your firewall a bit. does that affect the steering wheel depth noticeably?
some pics of your dash would be nice. you made that look awesome. mine is shortened and mocked up but not finished yet. looks about the same a yours for fitment. I will likely get another whole dash because this one is from a chain smoker's vehicle and the smell just doesn't go away. being a non smoker I really notice it. mock up is good anyway. get this one right and then copy the new smoke free one.
are the ss heels 20"? I like the 17's you have picked out.
Old 04-01-2019, 11:10 PM   #20
Purcell69
Re: 1955 Chevy SS
Wow, that's slick!
Nice work!
-Joe
My '57 "Ram-rolet" not a NAPCO build: http://67-72chevytrucks.com/vboard/s...d.php?t=589917
Purcell69 is offline   Reply With Quote
Old 06-28-2019, 03:56 PM   #21
Fast Chevy
Re: 1955 Chevy SS update
Not finished but finished enough to drive! Here some photos.
Old 06-28-2019, 07:52 PM   #22
mongocanfly
Post Whore
mongocanfly's Avatar
Re: 1955 Chevy SS
Nice!!!!!....
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 06-29-2019, 09:24 PM   #23
Fast Chevy
Re: 1955 Chevy SS
Thanks Greg,
Have to paint tailgate, put on mirrors, n finish interior, but getting close.
Jeff
Old 06-30-2019, 03:08 PM   #24
dug224
dug224's Avatar
Re: 1955 Chevy SS
Man, that turned out great!!! I'm impressed with the number of things you fit under the hood!! I was running out of room quick. Well done. If you have them, post detailed pictures so we can all study.
dug224 is offline   Reply With Quote
Old 06-30-2019, 05:56 PM   #25
Fast Chevy
Re: 1955 Chevy SS
Didn’t take alot of detailed photos, but if there is something u really want to see let me know n I’ll see if I can take a photo of. I removed alot of the 55 metal wheel well to give me more room under the hood n replaced them with the plastic wheel wells from the trailblazer.
It worked out pretty good, had some cutting n fitting to do. I have tried to use as much as I could from the trailblazer, even utilizing the SS n Chevy emblems instead of buying the expensive 55 emblems.
Jeff
