Old 03-09-2019, 11:15 AM   #1
69GMC910
MOTORHEAD!
69GMC910's Avatar
Dakota Digital VHX question.
What are peoples thoughts on these? Are they easy to install? Can you use the stock gear shift indicator and turn signal indicator with them? Any other pros/cons.
TIA!
82 GMC High Sierra
VortecPro 496
12 Bolt, 3.42's
AFR 265
Holley 850
Performer RPM Air Gap
Hooker 2455's
TCI Turbo 400 Super Street Fighter
TRRC 12 Bolt
Eaton Posi
Mark Williams Axles
Cal-Tracs
Hoosier 30x10.5 Radial Slick
Full weight long box pickup
Current best- 11.33@117mph
69GMC910 is offline   Reply With Quote
Old 03-09-2019, 12:50 PM   #2
67lowred
67lowred's Avatar
Re: Dakota Digital VHX question.
Yes to both your questions. Here is a link to the install instructions.
http://www.dakotadigital.com/pdf/VHX-73c-pu.PDF
Just received a VHX for my ‘74 on Thursday, but not ready to install it. It looks straight forward and simple. Manuals seem well organized and the quality is good. I’m not using the stock gear selector so I also ordered their GSS-2000 gear selector for $96.
67lowred is offline   Reply With Quote
Old 03-09-2019, 02:04 PM   #3
69GMC910
MOTORHEAD!
69GMC910's Avatar
Thank you!
82 GMC High Sierra
VortecPro 496
12 Bolt, 3.42's
AFR 265
Holley 850
Hooker 2455's
TRRC 12 Bolt
Eaton Posi
Mark Williams Axles
Cal-Tracs
Old 03-09-2019, 03:14 PM   #4
Big Moose
These are very nice, fit is pretty good, though on ours, I had to loosen the screws on the bracket on the back side to achieve a good fit. The only thing I don't like about them is the numerals on the speedo are a little small, but they have a new style out now, I do believe they're called RTX ?, these look very nice, but are a little more money. If I were to do it again I would spring for these.
Regarding the gear shift indicator, it doesn't work too good for trying to use it the way they have it setup for using the stock style. As mentioned above they have the GSS-2000 available as an option.
Big Moose is offline   Reply With Quote
