Old 03-11-2019, 10:33 AM   #1
Nickelcharlie
Starter not engaging,but not all the time!
Is my starter going bad or do I have a bad spot on my flywheel?
Sometimes, not always when I try to start my truck the starter will whine but not engage. Second try usually will start the truck. I guess if teeth were missing on the flywheel it might not ever engage unless the flywheel was rotated some, is this right? Thanks inadvance!
Nickelcharlie is offline   Reply With Quote
Old 03-11-2019, 11:23 AM   #2
mongocanfly
Post Whore
mongocanfly's Avatar
Re: Starter not engaging,but not all the time!
Bendix is bad most likely...
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 03-11-2019, 11:48 AM   #3
rpmerf
rpmerf's Avatar
If the starter spins, but doesn't engage the flywheel, the gear is not popping out.
If it grinds really bad, I would look at the flywheel and spacing.
1970 C20 Custom Camper - 350, TH350
1997 GMC Suburban
1994 Acura Integra GSR
1987 Dodge Daytona Shelby Z
rpmerf is offline   Reply With Quote
Old 03-11-2019, 02:56 PM   #4
Big Moose
as mongo said, your Bendix is going bad
Big Moose is offline   Reply With Quote
Old 03-11-2019, 04:49 PM   #5
bigdaddy4x4
bigdaddy4x4's Avatar
yes your starter is getting ready to go .they are not to bad to change out and cheap just don't strip the 2 block mounting bolts
bigdaddy4x4 is offline   Reply With Quote
Old 03-12-2019, 02:04 PM   #6
Nickelcharlie
Thank you mongocanfly, rpmerf, Big Moose, and bigdaddy4X4. I am off to get a replacement starter.
Old 03-12-2019, 09:59 PM   #7
kidatheart
kidatheart's Avatar
This is just my opinion, but if I have a starter on a vehicle that seems to "fit" good, as in sounds good when starting(when it works) and doesn't grind-sounds like it meshes good with the flexplate or flywheel, I would rather rebuild or have rebuilt the starter I have rather than getting a different one. I have had too many problems with replacements need shimmed to get them to sound right when starting....It can be a real pain to get them right.
kidatheart is offline   Reply With Quote
Old 03-13-2019, 10:52 AM   #8
hatzie
Moderator
hatzie's Avatar
I would keep your old starter even if you get a re-built unit. The Chinese crap has poisoned the supply chain to the point that even an otherwise quality reman unit may not fit properly.
You can usually get yours re-built locally so you end up with a starter that actually fits.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 03-13-2019, 05:37 PM   #9
Honest Bob
Honest Bob's Avatar
Mine did that for a while and eventually started engaging but not disengaging, had to pull the battery cable off to get it to stop cranking.
I had luck taking the starter apart and turning all the contacts inside around to a fresh side (they were reversible in my starter).
Honest Bob is offline   Reply With Quote
