Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > Heavy Haulers
Old 03-20-2019, 08:43 PM   #1
mike_66_c60
66 c60 transmission fluid?
Hey guys i am going to replace fluid on my truck since the brakes are all fixed. what kind of transmission fluid does my transmission take and where do i fill and drain. it has the pto attached to it for my dump bed. i am going to degrease it tmrw and take some pics. thanks.
mike_66_c60 is offline   Reply With Quote
Old 03-21-2019, 07:48 PM   #2
Robert1970C20rstbukt
Robert1970C20rstbukt's Avatar
Re: 66 c60 transmission fluid?
Regular 80W90 GL5 gear oil, will work just fine.
RJD
1984 Chevrolet C30 welding truck 454/SM465
1977 GMC C15 pickup 350/TH350
1970 Chevrolet C20 pickup 350/TH400
1970 Chevrolet K20 Suburban 454/TH350
1969 GMC 8500 478M V6/5 spd winch truck
Robert1970C20rstbukt is offline   Reply With Quote
Old 03-21-2019, 08:44 PM   #3
Nobighurry
Drain plug should be on the bottom and the fill will be on the side. My pto is mounted on passenger side, I filled on drivers. I took a piece of clear hose, maybe 1/2" and connected it to a funnel. Made adding fluid super easy. Of course you can buy a hand pump.
Nobighurry is offline   Reply With Quote
Old 03-22-2019, 08:35 PM   #4
luvmytruck
do not use 80-90 wt without checking trans manufacture specs my dana spicer required special 50 wt and someone had put in the wrong oil causng it to always grind into gear If you have a 5 spd spicer I can send you copies of the manual that says what oil to use gary
luvmytruck is offline   Reply With Quote
Old 03-25-2019, 10:04 PM   #5
mike_66_c60
thank you, mine is a 4 speed, pto is on the driver side, i found the drain plug and fill.
