Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1960 - 1966 Chevrolet & GMC Pickups Message Board > 60-66 Suburbans
Old 04-01-2019, 04:40 AM   #1
Marine1996
Lowering with stock wheels
I’m wanting to lower my truck and put 6 lug disc on the front any body have any suggestions on a brand for a disc brake conversion? And also how much to lower it. I want to run stock 15” wheels and caps if I can
Marine1996 is offline   Reply With Quote
Old 04-01-2019, 07:42 AM   #2
bhap
bhap's Avatar
Re: Lowering with stock wheels
My understanding is that disc brakes will not fit stock wheels. Lots of discussion on which brand is best. Most spindles offer stock and 2" drop, then you can use springs or air bags to go lower. Use the search function or google like this: "66 C10 disc brake conversion site:67-72chevytrucks.com"
You'll find lots of opinions. Good luck!
bhap is offline   Reply With Quote
Old 05-07-2019, 03:24 PM   #3
Southcity
Southcity's Avatar
"I want to run stock 15inch wheels and caps if I can"
You can, kinda. In order to run a stock wheel and cap look with disc brakes you would need one of two things:
1. A used 6 lug steel wheel from the 73-84 year trucks. These year trucks came with disc brakes and so the stock wheel has the proper offset to fit disc brakes and the nubs to accept the dogdish hubcap
2. Buy a brand new 6 lug steel wheel now made by Wheel Vintiques:
https://www.wheelvintiques.com/o-e-6...ed-finish.html
I believe Summit Racing sells them too
66 GMC Suburban Custom
66 Chevy K10 Suburban
Southcity is offline   Reply With Quote
Old 05-10-2019, 10:36 PM   #4
chakah
chakah's Avatar
On stock wheels, you wanna find, I believe from '72 Blazer wheels. Go to any salvage yard and if you're lucky, you'll find some. Best way to tell from the front is they have 4 nubs for the caps instead of 3. The reason is, your stock 3 nubs have a certain degree offset where as the 4 nubs are more squared. I hope you're picturing this, but that's where lowered spindle disc brakes tend to rub on the caliper.
Yes, another option is Wheel Vintiques, but not sure if your stock caps work. Never tried myself.
On brands, I used McGaughy's kit. Great product so far.
Good luck
This pic is with Wheel Vintiques
This is with stock 4 nub wheels
Kind of hard but, notice the 4 nubs for caps
Name:  K5 Wheels.jpg
"El Jerry"
'03 3500 Duramax dually
'96 1500 ext. cab Chevy
'66 swb C-10
'63 Panel
'60 VW vert
'56 VW vert
chakah is offline   Reply With Quote
