04-03-2019, 07:20 PM | #1 |
Aftermarket trailing arm and rear sway bar
Looking at upgrading my trailing arms and adding rear sway bar on my LS powered C10 suburban. Looking at the ECE trailing arms, whats everyone's experience? Also does a rear sway bar worth the $$?
04-05-2019, 10:16 AM | #2 |
Re: Aftermarket trailing arm and rear sway bar
Why do you need to upgrade the T/A's? Is there something wrong w/them?
Factory T/A's work just fine as is. If you want to upgrade, change the front bushing to something that reduces flex & has less bind than the factory rubber bushing. Some small lengths of stitch welds to ensure they can't come apart doesn't hurt or partial plating like the 3/4 ton trucks got (they used the same arms, they were just partially plated from the factory). Switching to solid, tubular (square or round) T/A construction w/a poly bushing up front will stiffen things up. It will also cause binding faster than the OE set-up would since there's no ability to flex like the suspension design was intended to do.
04-05-2019, 10:22 AM | #3 |
My factory ones have quite a bit of rust in them and are splitting apart. One of axle bolt tubes on the driver's side is rotted through. Not sure of I can salvage them otherwise welding some plates top and bottom would help.
04-05-2019, 10:37 AM | #4 |
Then new aftermarket seems a solid choice if you can't find used replacements somewhere. If switching to a solid tubular type of construction, make sure to use a front bushing that allows movement/articulation (some type of spherical joint).
