Old 04-04-2019, 10:34 AM   #1
S10Fan
Old Heap Driver
99 Silverado A/C condensation drain
99 Silverado 1500, recently repaired/serviced the A/C, 40 degree vent air for a couple weeks. No condensation is draining from the firewall drain tube, no water on the interior floor (rubber mat). I bent a 1/8" piece of round bar and ran it up into the drain tube, no apparent blockage. I have to think some water would come out of the drain after each use.
How far up into the tube should I be trying to clean out? Should I remove the tube and try cleaning again?
I'd rather get ahead of this before I have 100 degree days and a wet floor.
Thanks in advance!
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver.
S10Fan is offline   Reply With Quote
Old 04-11-2019, 05:53 AM   #2
S10Fan
Old Heap Driver
Re: 99 Silverado A/C condensation drain
Update.....
I guess there hadn't been enough humidity in the air for much condensation to develop. The drain appears to be working normally with recent higher temperatures.
Bryan
Old 04-11-2019, 06:15 AM   #3
Glad it seems to be working OK now. Had no clue since I no longer have any late model trucks to look at..
