Battery Tray Modification
I am doing an ls swap and I have read that some members have modified the original battery tray to fit on the driver side and I was wondering if any one has done a write up or maybe has pictures of how they made it fit and work on the driver side. Thanks
Re: Battery Tray Modification
If you use the auxillary (spelling) battery tray the holes are already there, factory
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
You have to take the tray apart, (separate into two sides and the bottom) switch the two sides with each other and weld it back together. Or buy the aux tray. Either way, you have to drill at least one mounting hole in the core support.
I have a radical idea!
It’s funny, I’m actually doing that very thing right now. I’m having to add 2 holes the aux tray, but my truck is a ‘67. I think the later trucks have more holes in the firewall.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
I already separated the pieces but i guess i am not very imaginative because i dont see how to switch the around unless i use some angle to support the tray. Thats kinda why i was hoping for pictures.
![]() Join Date: Dec 2009
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
Check the boards for an auxiliary battery tray. If none there, Brother's sells them.
1970 C10 8' Fleetside, L6 250, 3 on the Tree. The most basic of pickup trucks! |
They are actually on sale right now.
Item Number: BBA72AX $99.99 https://www.brotherstrucks.com/67-72...tinfo/BBA72AX/
![]() Join Date: Dec 2003
Why do you need to do that for an LS swap?
https://www.ebay.com/itm/295742064443 |
I want the battery on the driver side for wiring purposes.
I plan to buy the brothers aux tray assy, just to have extra cranking power, although I don't need it...just my choice!!!
